Engine is in ... Next question |
Amphicar770 |
May 4 2016, 07:38 PM
Senior Member Group: Members Posts: 1,193 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
A big milestone, engine and tranny are back in car. (IMG:style_emoticons/default/beerchug.gif) Thanks to all who have helped me get this far.
I have reconnected clutch cable before anything else as I want to make sure this whole thing with the arm is correct. I now have 3/4 -1" play when pulling pedal up. I think there is still enough slack in cable that excess pressure is not on TOB. When pedal fully depressed to floor there is about 3/8" (rough measure) remaining before arm would hit the trans case. Here is pic of cable end. Does everything sound like it is within spec? Thx |
MarkV |
May 21 2016, 12:24 PM
Fear the Jack Stands Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None |
I think you are getting really close to figuring out the problem. You could pop the valve cover off and just check the #2 cylinder. Rather than go through the whole rotation procedure to check all of the valves just do #2. Rotate the engine until #2 intake is open and loosen #2 exhaust center the push rod and then set the clearance. Then rotate the engine again until the exhaust Valve is open and do the same procedure for the intake valve. Easy to do with a remote starter switch and the coil disconnected. If you don't have one do it with the car jacked up in 5th gear by rotating the tire.
Amphicar770 |
May 21 2016, 01:44 PM
I think you are getting really close to figuring out the problem. You could pop the valve cover off and just check the #2 cylinder. Rather than go through the whole rotation procedure to check all of the valves just do #2. Rotate the engine until #2 intake is open and loosen #2 exhaust center the push rod and then set the clearance. Then rotate the engine again until the exhaust Valve is open and do the same procedure for the intake valve. Easy to do with a remote starter switch and the coil disconnected. If you don't have one do it with the car jacked up in 5th gear by rotating the tire. Good point, focus on one cylinder at a time. |
Lo-Fi Version | Time is now: 23rd May 2024 - 04:36 PM |
