L-Jet Idle on new build with 9550 |
andreic |
May 21 2016, 09:23 PM
Member Group: Members Posts: 172 Joined: 21-December 15 From: Madison, WI Member No.: 19,479 Region Association: Upper MidWest |
Hello,
I am just finishing up a new engine build for a 1975 914 1.8L. The engine is mostly stock, except for the fact that I am using 96mm cylinders (1911cc total) and a Raby 9550 cam. Using the stock L-Jet fuel injection. I managed to get the engine started, broken in (25 minutes at 2500 RPM), all is well. I also adjusted the timing as per standard instructions (showing the L-Jet mark on the fan at 800 RPM with vacuum lines removed and plugged). The engine is accelerating smoothly and seems to have good power throughout the whole RPM curve (without a load, though, I am testing it outside the car). The only thing not working is the fact that it will die (stall) at idle. Does not matter if it is hot or cold. I tried the idle adjustment screw on the throttle body, and while I can perhaps get the idle up to 500 RPM with the screw all the way out, I can't get it to 900. And at 500 RPM it is very shaky. Any suggestions as to what I can do? I knew that using the 9550 cam with the L-Jet was going to give me trouble, but I hope there is some way to fix this. Tomorrow I want to check if there are any vacuum leaks, but I suspect there are none, I was quite careful with all the vacuum lines. If the problem is the cam, can the throttle be perhaps modified to let in more air at idle? Thanks, Andrei. |
andreic |
May 22 2016, 07:10 AM
OK, trying to understand all the responses above. From what I have read, having a leak in the L-Jet makes the idle slower not faster. This is what the Cap'n seemed to be saying in the older thread, which I had read. So I am now looking for vacuum leaks. What I read I should try to do is spray carb cleaner at the manifold body (from the outside), and see if that changes the idle -- that would be an indication of leaks.
There are no air bleed passages at the idle adjustment screw as far as I can tell, it is just a big fat screw which adjusts how much air goes past the butterfly valve when it is closed. I will do a valve adjustment today, and re-check the timing. Was the comment about the airvalve referring to the AAR (auxiliary air regulator)? I did not see any adjustments on it... Finally, the valve covers have been cleaned during the rebuild, and new gaskets installed. I did not put any kind of sealant to seal them better (they do not leak oil at all now) as per Jake Raby's comments in his Type IV rebuild video. Can there be a vacuum leak there? Thanks! |
messix |
May 22 2016, 09:20 AM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
OK, trying to understand all the responses above. From what I have read, having a leak in the L-Jet makes the idle slower not faster. This is what the Cap'n seemed to be saying in the older thread, which I had read. So I am now looking for vacuum leaks. What I read I should try to do is spray carb cleaner at the manifold body (from the outside), and see if that changes the idle -- that would be an indication of leaks. There are no air bleed passages at the idle adjustment screw as far as I can tell, it is just a big fat screw which adjusts how much air goes past the butterfly valve when it is closed. I will do a valve adjustment today, and re-check the timing. Was the comment about the airvalve referring to the AAR (auxiliary air regulator)? I did not see any adjustments on it... Finally, the valve covers have been cleaned during the rebuild, and new gaskets installed. I did not put any kind of sealant to seal them better (they do not leak oil at all now) as per Jake Raby's comments in his Type IV rebuild video. Can there be a vacuum leak there? Thanks! not the aar. the big intake module that connects to the throttle body. it has the air metering flapper valve. on the top as you look at it there is a recessed slotted screw that meters air to by pass the flapper valve to adjust idle mixture. clockwise leans it out, counterclockwise richens it. verify all the vacuum lines and fittings are connected and dont have cracks in them. l-jet is very sensitive to vacuum leaks. |
Lo-Fi Version | Time is now: 2nd June 2024 - 06:00 PM |
