| 914 |
May 3 2016, 08:17 AM
Senior Member ![]() ![]() Group: Members Posts: 468 Joined: 26-December 02 Member No.: 19 Region Association: Southern California
Any Ideas as what is the best battery for a 1971 914-4?
Thanks,914 |
| Cairo94507 |
May 23 2016, 08:21 AM
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,609 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
When it comes time for a battery, it is going to be a sealed battery for sure. No more leaking acid worries, regardless of a battery pad/liner.
| dlkawashima |
May 23 2016, 09:53 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,749 Joined: 1-October 10 From: San Jose Member No.: 12,234 Region Association: Northern California |
When it comes time for a battery, it is going to be a sealed battery for sure. No more leaking acid worries, regardless of a battery pad/liner. Online battery purchases are 25% off at Pep Boys right now. But be careful about the end date because there appears to be some confusion on their own site about when the sale ends. One link says the end of May while others say the end of June. Might want to call a store to verify. Here is what gets pulled up when doing a search for Bosch AGM batteries: https://www.pepboys.com/search/?term=bosch+agm+battery Example ... ![]() |
914 914-4 Battery? May 3 2016, 08:17 AM
Amphicar770 A lot of people use the Optima batteries. No worr... May 3 2016, 08:49 AM
malcolm2
A lot of people use the Optima batteries. No wor... May 3 2016, 09:11 AM
era vulgaris
[quote name='Amphicar770' post='2339580' date='Ma... May 3 2016, 06:21 PM
1TRICK6 Bosch 96R battery fits perfect.
Check PepBoys, usu... May 3 2016, 09:13 AM
malcolm2 Something else I really like are my connectors. I... May 3 2016, 09:22 AM
914 Thanks everyone for the reply's.I got the Bosc... May 3 2016, 06:10 PM
porsche913b_sp
Thanks everyone for the reply's.I got the Bos... May 3 2016, 08:16 PM
struckn If it's a Vented Battery, such as I have, buy ... May 4 2016, 07:42 AM
Drums66
If it's a Vented Battery, such as I have, buy... Oct 10 2017, 01:41 PM
championgt1
Thanks everyone for the reply's.I got the Bo... May 5 2016, 09:25 AM
914 Here is the Bosch battery..Again Thanks everyone f... May 4 2016, 05:35 PM
Amphicar770
Here is the Bosch battery..Again Thanks everyone ... May 5 2016, 08:24 AM
914 Always used a mat on my Four and Six..
914 May 5 2016, 08:59 AM
JFG Any chance you can post the dimendions of the bosc... May 23 2016, 03:22 AM
dlkawashima The battery purchased by the original poster is a ... May 23 2016, 04:32 AM
1stworks Here's what I did.
http://www.914world.com/b... May 23 2016, 06:59 AM
fslick dlkawashima, do you run a size 34? Would really li... Oct 9 2017, 01:58 PM
Philip W.
[quote name='Cairo94507' post='2349034' date='May... Oct 10 2017, 07:38 AM
fslick Dr. Phil -- if you do order the Bosch AGM from pep... Oct 10 2017, 11:52 AM
Philip W.
Dr. Phil -- if you do order the Bosch AGM from pe... Oct 10 2017, 11:56 AM
arne I put a Miata U1R AGM in mine. Smaller, lighter, c... Oct 9 2017, 04:22 PM
fslick Cool! I think next go around I'll do AGM. ... Oct 9 2017, 09:03 PM
ThreeV8s
I put a Miata U1R AGM in mine. Smaller, lighter, ... Nov 3 2017, 05:34 PM
ThreeV8s
I put a Miata U1R AGM in mine. Smaller, lighter,... Nov 6 2017, 09:16 AM
Coondog RE: 914-4 Battery? Oct 9 2017, 10:06 PM
Rand It's a no-brainer to avoid lead-acid. :sick: T... Oct 9 2017, 10:48 PM
gereed75 It is pretty common in the experimental aircraft w... Oct 10 2017, 07:25 AM
arne
It is pretty common in the experimental aircraft ... Oct 10 2017, 11:55 AM
malcolm2
It is pretty common in the experimental aircraft... Oct 11 2017, 08:44 AM
mzalanka
[quote name='arne' post='2536236' date='Oct 10 20... Oct 12 2017, 10:09 PM
porschetub
It is pretty common in the experimental aircraft ... Oct 10 2017, 03:27 PM
ValcoOscar Another option:
25% Off Online Orders of Select H... Oct 11 2017, 08:52 AM
ThreeV8s
Another option:
25% Off Online Orders of Select ... Oct 12 2017, 07:24 PM
ThreeV8s Can anyone confirm if this "non-spillable... Oct 29 2017, 05:02 AM
Elliot Cannon I just found this tonight. http://www.batterymart... Nov 6 2017, 10:05 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:32 PM |
