L-Jet Idle on new build with 9550 |
andreic |
May 21 2016, 09:23 PM
Member Group: Members Posts: 172 Joined: 21-December 15 From: Madison, WI Member No.: 19,479 Region Association: Upper MidWest |
Hello,
I am just finishing up a new engine build for a 1975 914 1.8L. The engine is mostly stock, except for the fact that I am using 96mm cylinders (1911cc total) and a Raby 9550 cam. Using the stock L-Jet fuel injection. I managed to get the engine started, broken in (25 minutes at 2500 RPM), all is well. I also adjusted the timing as per standard instructions (showing the L-Jet mark on the fan at 800 RPM with vacuum lines removed and plugged). The engine is accelerating smoothly and seems to have good power throughout the whole RPM curve (without a load, though, I am testing it outside the car). The only thing not working is the fact that it will die (stall) at idle. Does not matter if it is hot or cold. I tried the idle adjustment screw on the throttle body, and while I can perhaps get the idle up to 500 RPM with the screw all the way out, I can't get it to 900. And at 500 RPM it is very shaky. Any suggestions as to what I can do? I knew that using the 9550 cam with the L-Jet was going to give me trouble, but I hope there is some way to fix this. Tomorrow I want to check if there are any vacuum leaks, but I suspect there are none, I was quite careful with all the vacuum lines. If the problem is the cam, can the throttle be perhaps modified to let in more air at idle? Thanks, Andrei. |
andreic |
May 23 2016, 02:29 PM
OK, I checked all valve settings. The are at 0.006 all around now (the #2 cylinder was tight, got adjusted). I adjusted the timing per published procedures (remove the two vacuum hoses from distributor, cap them, get idle to 800 RPM, use timing light to get the timing mark on the fan to show up in the little window).
After all this the engine ran better, though not perfect. I can get it now to idle at about 500 RPM (the needle on the tach barely lifts up), with the adjustment screw on the throttle body all the way out. If I remove and cap off the retard vacuum line, the idle goes up to about 950. I can get the idle much higher (1300-1400) by advancing the timing a bit, but I am not sure how this will play out at higher RPMS's. I'd like an idle of around 800-850. What do you guys recommend? I can either get rid of the idle retard vacuum line, and leave the timing as it is (7.5 degrees BTDC at 800 RPM) or I could advance the timing and keep the idle retard vacuum line in place? I triple checked for vacuum leaks everywhere, and have found none. I even tried spraying carb cleaner everywhere around the vacuum lines/intake manifold, and nothing changed. Thanks, Andrei. |
timothy_nd28 |
May 23 2016, 03:06 PM
Advanced Member Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest |
pete000 |
May 23 2016, 03:54 PM
Senior Member Group: Members Posts: 1,885 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States |
After all this the engine ran better, though not perfect. I can get it now to idle at about 500 RPM (the needle on the tach barely lifts up) My friend, this is not 500 I recommend using the tachometer on the timing light if yours has one. My 914 Tach seems to be a bit off compared to the tachometer in my timing light. (914 tachometer reads a bit fast on my car) |
Lo-Fi Version | Time is now: 13th June 2024 - 05:49 AM |
