Torque Rear Axle Nuts, Can this be done at home? |
jack20 |
May 25 2016, 08:53 PM
Member Group: Members Posts: 406 Joined: 7-November 14 From: Granite Bay, CA Member No.: 18,099 Region Association: Northern California |
When I removed the rear axle nuts I bolted a 3' length of angle iron onto the hub and placed it on a jack stand. I attached a socket on one end of a breaker bar and used a floor Jack on th other side to break it loose.
I don't have a torque wrench that breaks at the value called for in the Haynes book which I think is around 160ft#. I doubt that most of us garage guys have this tool. What do you all recommend for tightening the rear axle nuts. Thank You, Jack |
stugray |
May 25 2016, 09:12 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
The best I can find is that you need ~220-250 ft-lbs.
If you target 250 ft-lbs (3000 inch-lbs) Get a cheater pipe for your breaker bar at least 3 ft long (unless you weigh less than 83 lbs). Take your weight (W) and use some algebra. Torque(T ft-lb) = Length(L ft) X Force(W lb) T = L X W If your weight is ~170lbs and you target torque is 250 ft-lbs: 250 = L X 170 solve for L L = 250/170 = 1.47 ft = 17.64 inches =~ 17 - 5/8 inches Make a mark on the cheater bar exactly 17-5/8 inches from the center of the socket. Torque by standing on that spot. (Math check => 17.625in * 170lbs = 2996.25 in/lbs) I take no responsibility if your foot slips or the socket slips or your breaker-bar snaps and you break an ankle. |
Lo-Fi Version | Time is now: 9th June 2024 - 05:23 PM |
