Torque Rear Axle Nuts, Can this be done at home? |
jack20 |
May 25 2016, 08:53 PM
Member Group: Members Posts: 406 Joined: 7-November 14 From: Granite Bay, CA Member No.: 18,099 Region Association: Northern California |
When I removed the rear axle nuts I bolted a 3' length of angle iron onto the hub and placed it on a jack stand. I attached a socket on one end of a breaker bar and used a floor Jack on th other side to break it loose.
I don't have a torque wrench that breaks at the value called for in the Haynes book which I think is around 160ft#. I doubt that most of us garage guys have this tool. What do you all recommend for tightening the rear axle nuts. Thank You, Jack |
stugray |
May 25 2016, 09:12 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
The best I can find is that you need ~220-250 ft-lbs.
If you target 250 ft-lbs (3000 inch-lbs) Get a cheater pipe for your breaker bar at least 3 ft long (unless you weigh less than 83 lbs). Take your weight (W) and use some algebra. Torque(T ft-lb) = Length(L ft) X Force(W lb) T = L X W If your weight is ~170lbs and you target torque is 250 ft-lbs: 250 = L X 170 solve for L L = 250/170 = 1.47 ft = 17.64 inches =~ 17 - 5/8 inches Make a mark on the cheater bar exactly 17-5/8 inches from the center of the socket. Torque by standing on that spot. (Math check => 17.625in * 170lbs = 2996.25 in/lbs) I take no responsibility if your foot slips or the socket slips or your breaker-bar snaps and you break an ankle. |
andys |
May 26 2016, 08:28 AM
Advanced Member Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None |
The best I can find is that you need ~220-250 ft-lbs. If you target 250 ft-lbs (3000 inch-lbs) Get a cheater pipe for your breaker bar at least 3 ft long (unless you weigh less than 83 lbs). Take your weight (W) and use some algebra. Torque(T ft-lb) = Length(L ft) X Force(W lb) T = L X W If your weight is ~170lbs and you target torque is 250 ft-lbs: 250 = L X 170 solve for L L = 250/170 = 1.47 ft = 17.64 inches =~ 17 - 5/8 inches Make a mark on the cheater bar exactly 17-5/8 inches from the center of the socket. Torque by standing on that spot. (Math check => 17.625in * 170lbs = 2996.25 in/lbs) I take no responsibility if your foot slips or the socket slips or your breaker-bar snaps and you break an ankle. Nothing at all wrong with this method. How you originate the required torque is of no consequence. Yes to being careful to not let the socket slip off the nut (You can put a block under the socket). Andys |
Lo-Fi Version | Time is now: 9th June 2024 - 08:06 PM |
