suby engine and megjolt - what single carb? |
jimkelly |
May 28 2016, 12:32 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
I was thinking maybe a Harley 40mm carb might work?
I figure a motorcycle type carb and be used in place of the throttle body? I have a few suby ej22 engines and thought i would fool around with carburation and with using stock ecu/fi too. http://www.randakksblog.com/single-carb-conversions/ Attached image(s) |
DBCooper |
May 29 2016, 08:29 AM
14's in the 13's with ATTITUDE Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California |
I'm afraid you'd be getting yourself into quite a lot of work just to achieve mediocrity. Carbs work, of course, but a single carb with long unheated runners isn't usually a very good idea. So if you're going to build the MegaJolt why not take it a step further, keep it F.I. and just build a full Megasquirt? No fabrication that way, it's almost plug-and-play, and since you wouldn't need to buy a carb and adapt it the cost should probably be about the same. But if you just HAVE to have carbs then why not two?
(IMG:http://www.914world.com/bbs2/uploads_offsite/i53.photobucket.com-2618-1464532174.1.jpg) |
Lo-Fi Version | Time is now: 10th June 2024 - 08:18 AM |
