Torque Rear Axle Nuts, Can this be done at home? |
jack20 |
May 25 2016, 08:53 PM
Member Group: Members Posts: 406 Joined: 7-November 14 From: Granite Bay, CA Member No.: 18,099 Region Association: Northern California |
When I removed the rear axle nuts I bolted a 3' length of angle iron onto the hub and placed it on a jack stand. I attached a socket on one end of a breaker bar and used a floor Jack on th other side to break it loose.
I don't have a torque wrench that breaks at the value called for in the Haynes book which I think is around 160ft#. I doubt that most of us garage guys have this tool. What do you all recommend for tightening the rear axle nuts. Thank You, Jack |
PanelBilly |
May 25 2016, 09:05 PM
914 Guru Group: Members Posts: 5,817 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
I used a breaker bar with a pipe on it, while the wheels were on the ground and the brake was on.
Drums66 |
May 30 2016, 06:49 PM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
I used a breaker bar with a pipe on it, while the wheels were on the ground and the brake was on. ...The method I've always used..... (IMG:style_emoticons/default/idea.gif) (also taking it off!) (IMG:style_emoticons/default/bye1.gif) |
Lo-Fi Version | Time is now: 9th June 2024 - 10:05 PM |
