| nwm5709 |
May 31 2016, 11:29 AM
Newbie ![]() Group: Members Posts: 29 Joined: 7-January 16 From: Raleigh, NC Member No.: 19,536 Region Association: South East States |
So I've recently looked at another 914 for sale. It's a very nice car on the outside, but when the owner told me its completely rust free of course I was suspicious. I found two small holes in the hell hole area. Generally, the underbody of the car is solid and the door gaps are good.
Attached are some pictures of the hell hole area which is the only rust I could find. I have not seen the longs with the rockers off, but I did get under the car on a lift. Image 1 - the hell hole from the top Image 2 - looking at another spot, below the hell hole from under the car. Image 3 - Not sure if this helps, but it is a shot behind the rocker on the passenger side. Assuming there isn't any more, is this rust a minimal repair? Would cutting out around the two holes and welding a small patch be a good repair or would it take more work? Note, this is not meant to be a project car, but some repairs are OK. Attached thumbnail(s) |
| nwm5709 |
Jun 1 2016, 07:41 AM
Yes I agree. The vertical section behind the fuel pump would need to be patched. Besides that and the small hole on top (and maybe the screwed in battery tray), everything else looks pretty solid.
Is it safe to say this car could be driven for a few years without much concern? Attached thumbnail(s) |
nwm5709 How bad is this rust? May 31 2016, 11:29 AM
SirAndy Assuming there isn't any more, is this rust a ... May 31 2016, 11:49 AM
Chris914n6 The surrounding area that is pitted is bad metal a... May 31 2016, 02:10 PM
Andyrew Looks pretty typical. I would say you could patch ... May 31 2016, 02:44 PM
nwm5709
Looks pretty typical. I would say you could patch... May 31 2016, 08:54 PM
Chris914n6
Looks pretty typical. I would say you could patc... May 31 2016, 09:49 PM
Andyrew I actually meant the part behind th battery, its a... Jun 1 2016, 06:55 AM
RobW I've seen fully repaired and painted hell hole... Jun 1 2016, 07:37 AM
Andyrew Should be, but rust spreads. Grab some kind of rus... Jun 1 2016, 08:39 AM
dlee6204 :agree:
The rust should really be treated if yo... Jun 1 2016, 08:42 AM
Chris914n6 The engine shelf is not my "vertical" pa... Jun 1 2016, 04:03 PM
rick 918-S Way worse than that. The second layer of metal is ... Jun 1 2016, 04:19 PM
nwm5709 Thanks for everyone's input, but I got outbid ... Jun 1 2016, 05:32 PM
jmitro good for you for doing your homework and not rushi... Jun 1 2016, 07:00 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:19 PM |
