engine removal, do I need to disconnect alternator? |
ggenovez |
May 29 2016, 07:27 PM
Newbie Group: Members Posts: 19 Joined: 8-December 14 From: DFW Member No.: 18,201 Region Association: None |
Hi all,
I'm removing the engine from my 914 and found some instructions about engine removal. On article says to "disconnect alternator harness". No pictures or other information. What does that mean? engine tins need to be removed? Any pics? Thanks! |
wndsnd |
May 31 2016, 06:46 AM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
PM Sent
ggenovez |
May 31 2016, 06:42 PM
PM Sent Gentlemen, all I can say is WOW! I love all the information! SO here is the other part, it was converted to carbs. so no ECM. I'm guessing I don't need anything on the alternator side to remove it. I am having another issues. The shift linkage is ceased and the 4mm hex is rounded. I tried penetrating oil, heat, cutting a notch, welding a nut (kept falling) any ideas to remove it? Thanks again. G |
Amphicar770 |
Jun 1 2016, 09:29 AM
Senior Member Group: Members Posts: 1,198 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
PM Sent Gentlemen, all I can say is WOW! I love all the information! SO here is the other part, it was converted to carbs. so no ECM. I'm guessing I don't need anything on the alternator side to remove it. I am having another issues. The shift linkage is ceased and the 4mm hex is rounded. I tried penetrating oil, heat, cutting a notch, welding a nut (kept falling) any ideas to remove it? Thanks again. G Take a similar sized torx bit and tap it into the allen bolt head with a hammer. Hammer hard. Once it is well and truly wedged in, a careful turn of the wrench should loosen the bolt. |
Lo-Fi Version | Time is now: 12th June 2024 - 10:53 PM |
