Does 914 bliss ever last more than 500 miles? |
airsix |
Oct 8 2004, 10:38 AM
I have bees in my epiglotis Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 |
After yesterday's discussion about ignition advance curves I decided to go educate myself a bit because I was convinced that the vacuum advance curve I'd programmed into my ECU was not right. WOT performance was perfect, but below 3,000rpm at part throttle there was a dead spot and sometimes a little bucking that was driving me nuts. So I went to shoptalkforums and read all the threads about advance curves and vacuum advance. As I suspected. I needed to extend my vacuum advance to include manifold pressures closer to atmospheric (I was only using vacuum advance at high vacuum). Wow. What a difference in drivability. Much better.
Less than 5 minutes later as I pulled up to a stop sign in a happy blissful state I dissengaged the clutch and there was a loud SNAP! as a pressure plate spring(s) broke. GGRRRRRrrrrrr! Some days I just want to throw a match on it and walk away. Mike, don't feel bad that you're pulling your motor this weekend. We'll be doing it together. (sigh) -Ben M. (with a new KEP StageII paperweight) |
J P Stein |
Oct 8 2004, 01:28 PM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
QUOTE(synthesisdv @ Oct 8 2004, 09:48 AM) I thought the KEP PP were supposed to be the best. When I bought my stage I KEP clutch, the guy tole me to use my stock 6 spring disc......after I had asked about all the trickshit I had heard about.....OK, I dodit. No problems. Ben: These are really pretty simple cars and can be made more simple in the interest of both power and longevity. I'm a firm beliver in KISS. |
Lo-Fi Version | Time is now: 7th June 2024 - 02:54 AM |
