JeffBowlsby |
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,974 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
I hear they are done to eliminate valve adjustments on a T4 motor.
Other pros/cons? Is there machining required or are they drop in and thus reversible? |
MichaelB |
Newbie ![]() Group: Members Posts: 23 Joined: 24-June 12 From: Wisconsin Member No.: 14,598 Region Association: None ![]() |
I am not the expert opinion you are looking for but on the engine I rebuilt, started with a GA case (supposedly "unmolested") motor that had hydraulic lifters and dished pistons (which with the 914 2.0 heads must have dropped the compression a pretty good bit). I replaced both the pistons and added a 9590 kit. The case did have the secondary oil pressure relief valve (under cylinder 1) and it had copper plug behind the screw/plug to block it off. I believe most bus motors with hydraulic lifters had this plugged from the factory. As we know the bores for these relief valves are often poor/irregular or worn (and leak or stick). If you have a secondary valve, addressing it might be a consideration in keeping pressure up for the hydraulic lifters.
Lo-Fi Version | Time is now: 12th July 2025 - 11:21 AM |
