> 914-6 Engine Wiring Harnesses, Conversion or Stock, Plug & Play
IronHillRestorations
post Jan 25 2005, 10:58 PM
I. I. R. C.
I've just taken recipet of color coded wiring, PVC insulating, and heat shrink tubing for 914-6 engine wiring harnesses. I can make a stock or custom harness for your application, or sell you a kit to make your own. Some core connectors are required. If you have a internally regulated alternator you may be able to eliminate the relay board and brackets, for a cleaner less cluttered engine bay. The black PVC insulating jacket and heat shrink tubing makes for a very OEM appearance.
If you are going through all the trouble of putting a flat six in your car, give it a professional looking wiring harness, not one covered with electrical tape!
All connections are crimped AND soldered!
>>>>Price Edit as of Sept 14, 2017
Custom made harnesses start at $325 plus your core CDI box plug and boot. Custom harnesses available and depending on the relay board and circuits required. The price of Porsche factory connectors and boots has really gone up.
A factory 14 pin male connector to plug directly into the 14 pin female connector in your 914-4 harness (if you have removed the relay board) is $48
A new rubber grommet where harness goes through the rear of the 914-6 engine tin is $8.50
E-mail me at: perry.kiehl@hotmail.com
Or call 731 733-8482
Perry Kiehl
914 Network
NS914
post Jun 14 2013, 07:56 AM
Hi Perry,
I am restoring / rebuilding my ’74 and need help with wiring! The latest project for the 914 is restoring / rebuilding my Wiring Harness....do you see a common thread here....ugh! Its a real mess!
I need to replace most of the front harness as it has been beaten up with what I think was the spare tire being slammed on it before I owned the car and likely just years of abuse. I would really like to stay period correct re wire / insulation colors etc. Can you direct me to your website or otherwise let me know what you carry / make to replace the harness up front.
I am going to replace the Fuse Panel as well with a panel from JWest Engineering. So in a nutshell, I need to replace the front harness so far….can you help me out? A side note, I have removed the side signals that were in the front fenders.
Grant
post Jun 14 2013, 10:15 AM
I. I. R. C.
Sorry but for now, all I'm doing is engine harnesses. I can do a 4 cyl engine harness too, but Jeff Bowlsby is the man on that, and I'm not going to step on his corner.
QUOTE(NS914 @ Jun 14 2013, 05:56 AM) *
Hi Perry,
Grant
porschetub
post Jun 4 2016, 12:51 AM
[quote name='9146986' date='Jun 15 2013, 04:15 AM' post='1879965']
[quote name='NS914' post='1879920' date='Jun 14 2013, 05:56 AM']
Hi Perry,
I am interested in a custom loom or kit for my six conversion,hope you are still doing them ?email sent,cheers.
Perry Kiehl Clone
post Jun 5 2016, 06:29 AM
Unregistered
[quote name='porschetub' date='Jun 3 2016, 10:51 PM' post='2354524']
Hi Perry,
[/quote]
My new email is: perry.kiehl@hotmail.com I've only done a handful of DIY kit's so I've stopped doing that, but I can make you a custom harness for your conversion.
9146986   914-6 Engine Wiring Harnesses   Jan 25 2005, 10:58 PM
jdogg   This deserves a bump....Perry not only made an awe...   Jun 3 2006, 07:00 PM
bag5rcg   Hi Perry....Are you still making harnesses for 6 c...   Dec 26 2008, 08:03 PM
9146986   Yes, I still do this. PM me for details.   Dec 27 2008, 10:20 AM
9146986   Here's a pic of a very correct 914-6 reproduct...   Feb 3 2009, 09:41 AM
9146986   Here's a detail shot of the repro 6 harness at...   Feb 4 2009, 08:46 AM
9146986   Here's a detail shot of the CD box connector. ...   Feb 4 2009, 08:50 AM
mikez   Looks excellent. The engine and trans is now comp...   Feb 5 2009, 03:33 PM
sixnotfour   very nice, what does that harness cost approx ?   Feb 5 2009, 05:03 PM
9146986   very nice, what does that harness cost approx ? ...   Jan 9 2010, 02:14 PM
9146986   DIY kits are NLA   Jan 9 2010, 02:08 PM
salomon99   PERRY. PM SEND.   Apr 23 2010, 06:07 AM
9146986   Here's a "Plug and Play" unit that...   Jun 20 2012, 04:52 PM
NS914   Hi Perry, I am restoring / rebuilding my ’74 and...   Jun 14 2013, 07:56 AM
9146986   Sorry but for now, all I'm doing is engine har...   Jun 14 2013, 10:15 AM
NS914   Thanks Perry, I will follow up with Jeff or altern...   Jun 17 2013, 09:48 AM
porschetub   [quote name='9146986' date='Jun 15 201...   Jun 4 2016, 12:51 AM
Perry Kiehl Clone   [quote name='9146986' date='Jun 15 20...   Jun 5 2016, 06:29 AM
porschetub   [quote name='9146986' date='Jun 15 2...   Jun 15 2016, 02:41 AM
mb911   Perry will be in touch soon for my 6 conversion.. ...   Jul 6 2016, 07:26 PM
- Lo-Fi Version Time is now: 8th October 2026 - 07:05 AM
