| Wyvern |
Jun 7 2016, 12:42 AM
Member ![]() ![]() Group: Members Posts: 324 Joined: 7-October 15 From: San Francisco (East Bay) Member No.: 19,245 Region Association: Northern California |
I have these shocks on my 73 1.7
They seem "ok" but just want to understand their adjustment. From my research they are Koni "Reds" Question 1 ... My car rides high (I think so) Measuring the "donuts" as what I understand is the preferred method I am at 6 1/2" on the rear and 5 1/2 at the front. Am I correct that the clip on the spring perch can be moved down to correct rear ride height ? ... then adjust the front torsion bars (yes ,,, then alignment) I thought they had 5 grooves. Looks like (I am in 2nd from the top / highest. What height should I be targeting ? Question 2 ... I have found 3 different instructions on adjusting the compression / rebound . any help with the correct way and info ? Thanks ![]() |
| Larmo63 |
Jun 7 2016, 06:32 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,267 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
I would drop the rear down to the lowest setting and work my way back up.
The front settings are a completely different story. |
Wyvern Help with rear shocks and adjustment please Jun 7 2016, 12:42 AM
Wyvern
I would drop the rear down to the lowest setting ... Jun 7 2016, 11:18 AM
Luke M To adjust the koni shock you need to turn the litt... Jun 7 2016, 06:35 PM
Wyvern Thanks "Luke" ... I saw your post after ... Jun 7 2016, 10:23 PM
r_towle Drop them to the bottom notch.
Set the front end a... Jun 7 2016, 10:26 PM
Wyvern ^^^ Tnks
Hmmmm . if my goal was front 3/8 lower t... Jun 7 2016, 10:44 PM
r_towle No,
Your rear shocks have adjustable spring perch... Jun 7 2016, 10:47 PM
Wyvern
No,
Your rear shocks have adjustable spring perc... Jun 7 2016, 11:59 PM
r_towle Btw, the proper and correct setting is the front i... Jun 7 2016, 10:51 PM![]() ![]() |
Lo-Fi Version | Time is now: 16th October 2026 - 09:40 AM |
