> Help with rear shocks and adjustment please
Wyvern
post Jun 7 2016, 12:42 AM
I have these shocks on my 73 1.7
They seem "ok" but just want to understand their adjustment.
From my research they are Koni "Reds"
Question 1 ... My car rides high (I think so)
Measuring the "donuts" as what I understand is the preferred method I am at 6 1/2" on the rear and 5 1/2 at the front.
Am I correct that the clip on the spring perch can be moved down to correct rear ride height ? ... then adjust the front torsion bars (yes ,,, then alignment)
I thought they had 5 grooves. Looks like (I am in 2nd from the top / highest.
What height should I be targeting ?
Question 2 ... I have found 3 different instructions on adjusting the compression / rebound . any help with the correct way and info ?
Thanks
Larmo63
post Jun 7 2016, 06:32 AM
I would drop the rear down to the lowest setting and work my way back up.
The front settings are a completely different story.
Wyvern
post Jun 7 2016, 11:18 AM
QUOTE(Larmo63 @ Jun 7 2016, 05:32 AM) *
Awesome ... thanks .
And even better because that's what I wanted to hear .. GO LOW
Yes I have some room on the front adjusters but am sure I will need to re-clock them if I go that low on the back.
I think the PO must have had this LOW at some time as the tires were worn badly. so thinking it had been lowered (never aligned) then brought what back up ... story on purchase was "new shocks" the rears are clean and that hopefully is true.
- Lo-Fi Version Time is now: 16th October 2026 - 09:41 AM
