| sdoolin |
Jun 6 2016, 12:24 PM
Member ![]() ![]() Group: Members Posts: 418 Joined: 1-May 14 From: LouKY Member No.: 17,299 Region Association: None |
I have searched - cannot find much on aftermarket CHT Gauges.
I am building a 2056 that will run dual Dells - would like to install a quality CHT gauge and wondering what others have used. |
| wes |
Jun 8 2016, 12:57 PM
wes ![]() ![]() ![]() Group: Members Posts: 1,600 Joined: 8-December 07 From: Ukiah Ca Member No.: 8,436 Region Association: Northern California
I have been reading this and was planning to put a VDO head temperature gauge in my consul as I'm installing a triple cluster gauge in the dash. Now hearing so much about the VDO head temperature gauge being so inaccurate looked into it more and have heard that if you use the sensor from the 911 it would turn better results.
Any thoughts or experience and I might add my engine is now a 2056 and will probably be doing a very minor bit of track time though nothing serious? |
sdoolin CHT Gauge Jun 6 2016, 12:24 PM
JoeD Researched this when I was looking to put one in m... Jun 6 2016, 12:37 PM
jeffdon
Researched this when I was looking to put one in ... Jun 7 2016, 09:16 AM
McMark
Researched this when I was looking to put one in ... Aug 28 2016, 06:43 AM
Mark Henry
I'm happy with my VDO gauge and sender. I... Apr 26 2017, 08:13 AM
BeatNavy I'm running a Dakota Digital.
I think there... Jun 6 2016, 01:18 PM
76-914
I think ther... Jun 6 2016, 06:32 PM
BeatNavy
[quote name='BeatNavy' post='2355644' date='Jun 6... Jun 6 2016, 06:50 PM
era vulgaris I'm running the MGL Avionics Stratomaster Velo... Jun 6 2016, 01:25 PM
Mueller
I'm running the MGL Avionics Stratomaster Vel... Jun 6 2016, 01:28 PM
Downunderman http://www.speedhut.com/gauges/Temperature...id=f2... Jun 6 2016, 02:11 PM
ThinAir
http://www.speedhut.com/gauges/Temperature...id=f... Jun 6 2016, 10:59 PM
Mueller For the true DIY guy...
https://learn.adafruit.... Jun 6 2016, 02:41 PM
sdoolin Thanks for the info - I knew y'all would be ab... Jun 6 2016, 05:52 PM
BeatNavy
First - can I assume these CHT gauges utilize the... Jun 6 2016, 06:20 PM
Steve Pratel
Thanks for the info - I knew y'all would be a... Aug 28 2016, 01:07 PM
Porschef Like Rob, I've been running a Dakota unit for ... Jun 6 2016, 07:26 PM
Jake Raby Never, under any circumstance should the stock CHT... Jun 7 2016, 06:52 AM
sdoolin Under the spark plug it is then. I assume these ga... Jun 7 2016, 07:00 AM
Mueller Jake, any special prep to the surface where the se... Jun 7 2016, 07:16 AM
tradisrad I'm happy with my VDO gauge and sender. I... Jun 8 2016, 01:31 PM
Mblizzard I just added the Dakota Digtial. I was wondering w... Aug 27 2016, 08:47 PM
BeatNavy
I just added the Dakota Digtial. I was wondering ... Aug 28 2016, 06:16 AM
Mblizzard
I just added the Dakota Digtial. I was wondering... Aug 28 2016, 08:22 AM
kgruen2
I just added the Dakota Digtial. I was wondering ... Apr 27 2017, 02:55 AM
eyesright I went with a VDO CHT along with an oil pressure a... Aug 27 2016, 08:57 PM
Steve Pratel I've been running the VDO gauge with the VDO s... Aug 28 2016, 12:57 PM
kgruen2
I have searched - cannot find much on aftermarket... Apr 26 2017, 02:07 AM
Elliot Cannon I have used a VDO gauge with the spark plug sender... Apr 26 2017, 10:54 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:11 PM |
