| jimkelly |
Sep 26 2015, 10:40 AM
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
i have a 1975 914 roller and a a few ej22 engines and a couple of suby 5 spd transaxles
https://www.diyautotune.com/shop/megasquirt...ed/microsquirt/ microsquirt with 8" harness $370 GM clt sensor 3/8 npt $17 GM iat sensor 3/8 npt $22 GM map sensor $75 3/8 npt tap $10 18x1.5 tap $12 18x1.5 bung for aem o2 sensor $4 AEM 30-4110 $165 Set of 6 Pcs Spark Plug Ignition Wire Lead For 2.8L VW Passat $30 VW bug Beetle golf oem 2.0 ignition coil pack assembly 032905106b $20 Subaru WRX OEM Crankshaft Timing Sprocket pn-13021AA141 $30 celica radiator 2 row - $170 (see post #2 and my v8 thread) exhaust header - $35 ebay (see post #152) (decided to go with wrx oem stock header for compactness) stainless fuel lines - $99 tangerine - 8mm supply and 8mm return stopper drive pinion - made myself http://www.914world.com/bbs2/index.php?showtopic=104513 stock 914 axles machined on one end - $150 Dutchman tires - 185x50x15 - $300+-[/b] engine cradle and trans hangars - mepstein $550 (see post #32) mr2 shifter - $35 ebay shift knob ebay $12 (see post #170) front bumper grills - $35 dflesburg stock style fuses - ebay $13 set of speed bleeders - $30 pelican brake peddle switch - $24 pelican ebrake handle assy with cable and equalizer - $56 bdstone914 lug bolts to roll car around my garage - free mark epstein set of nice complete late model doors - $150 (thanks lorin, series9, rat rod charlie) center section of fuse box - free mark epstein a front steel bumper - free mark epstein late model tach with single directional indicator - cabinetmaker $40 shipped : ) two pair front amber lens bought from 914rubber for both my cars. https://weddleindustries.com/products/1000186/1001853 - flange $50 shipped type 1 to type 2/4 starter 23300AA560 - http://www.914world.com/bbs2/index.php?showtopic=303903 /////////////////////////////////////////////////////////////////////////////////////////// looking forward to... good fuel mileage modern fuel injection modern 5spd transaxle - useable 1st gear for taking off from dead stop & in traffic light weight car big space in engine bay running some low profile 15 inch tires on 5.5" wheels - maybe 185x50x15 ////////////////////////////////////////////////////////////////////////////////////////// reference materials and links... http://www.shoptalkforums.com/viewtopic.php?t=136053 http://www.surrealmirage.com/subaru/swap/electrical.html http://legacycentral.org/ http://www.northursalia.com/modifications/...lschematics.pdf http://www.main.experiencetherave.com/subaru_manual_scans/ vanagon related links... http://subaruvanagon.com/conversion_services_Wiring.htm https://smallcar.com/vanagon/subaru-vanagon...cation-kit.html http://www.kennedyenginc.com/Pages/SubaruVanagonGen.aspx http://www.rockymountainwesty.com/v/vspfil...nstructions.pdf http://www.weidefamily.net/vanagon/HTML/05/main.html http://www.ultimatesubaru.org/forum/topic/...iring-diagrams/ http://www.numbchuxconversions.com/Files/Harness%20info.pdf http://consumerguide.com/used/1990-94-subaru-legacy/ pulling ej22 harness from subaru (Tim Seward) per tim 90 and 91 harnesses are same https://www.youtube.com/watch?v=GfQJnZBljsw be sure to watch all (busaru) segments https://www.youtube.com/watch?v=ENm6S3WkKJc Subaru engine test stand (Jeff Robenolt) https://www.youtube.com/watch?v=_IN5rfK9a_8 |
| jimkelly |
Jun 11 2016, 04:35 PM
ambitious, no. (IMG:style_emoticons/default/poke.gif) poking myself (IMG:style_emoticons/default/biggrin.gif)
frugal and on a tight budget, yes. (IMG:style_emoticons/default/hissyfit.gif) |
jimkelly jim kelly's 1975 914 suby build Sep 26 2015, 10:40 AM
jimkelly this ebay radiator was mentioned by a member. the... Sep 29 2015, 02:30 PM
jimkelly some sensor fake output info... from tonyakavw an... Sep 29 2015, 02:32 PM
r_towle Wait, what?
Don't you have a v8? Sep 29 2015, 04:04 PM
Smallblockbug Im pretty sure this is his other car. But yes he h... Sep 29 2015, 04:31 PM
jimkelly i have a wife, 2 boys, and two 914s. that is about... Sep 29 2015, 06:31 PM
Stacks914 I am sorry did you mention fuel mileage??? LOL jk... Sep 30 2015, 01:48 AM
jimkelly YES, yes i did. it will be my daily driver once c... Sep 30 2015, 07:01 AM
YES, yes i did. it will be my daily driver once ... Sep 30 2015, 07:09 AM
76-914 When does the build start? Not a fan of acquisitio... Sep 30 2015, 09:21 AM
When does the build start? Not a fan of acquisiti... Sep 30 2015, 09:39 AM
76-914
When does the build start? Not a fan of acquisit... Sep 30 2015, 04:00 PM
[quote name='mepstein' post='2245415' date='Sep 3... Sep 30 2015, 05:52 PM
jimkelly i'll try to blend ACQUISITION with ACTUAL BUIL... Sep 30 2015, 06:53 PM
mgp4591
i'll try to blend ACQUISITION with ACTUAL BUI... Oct 1 2015, 09:06 PM
jimkelly $35 ebay
actual unit as received Oct 1 2015, 06:33 PM
A&P Mech All those pieces and parts look familiar. :) What... Oct 1 2015, 06:50 PM
jimkelly Dutchman has been recommended by bigkat_83 who is ... Oct 2 2015, 08:52 AM
76-914
Dutchman has been recommended by bigkat_83 who is... Oct 2 2015, 09:47 AM
mgp4591 Sweet idea for the axles- I may just send my SVX a... Oct 2 2015, 10:38 PM
jimkelly sawtooths axles
>> has anyone used this dim... Oct 3 2015, 06:12 AM
76-914
sawtooths axles
>> has anyone used this di... Oct 3 2015, 08:20 AM
jimkelly your conversion was epic - others can see it here.... Oct 3 2015, 10:24 AM
jimkelly why I MUST HAVE a Subaru engine and trans :D
AL... Oct 3 2015, 06:15 AM
Chris H.
... Oct 3 2015, 01:34 PM
Justinp71
... Apr 1 2016, 05:37 PM
jimkelly OD of splined end of stock 914 axle is 1.066.
wha... Oct 7 2015, 12:56 PM
76-914
wh... Oct 12 2015, 08:20 PM
mepstein Jim - if you or someone will tell me how to remove... Oct 7 2015, 03:59 PM
mgp4591
Jim - if you or someone will tell me how to remov... Oct 7 2015, 04:53 PM
jimkelly once upon a time, i had a legacy parts car and rem... Oct 7 2015, 04:03 PM
jimkelly Ms_UZ43u4CQ Oct 7 2015, 05:10 PM
mepstein Thanks guys.
I'll probably cheat and have on... Oct 7 2015, 06:08 PM
jimkelly decided to drive the pickup truck to mark's sh... Oct 9 2015, 11:34 AM
jimkelly finally got my 1975 back onto some wheels and tire... Oct 10 2015, 04:10 PM
jimkelly how could i best protect these pin holed longs wit... Oct 12 2015, 11:07 AM
Andyrew
how could i best protect these pin holed longs wi... Oct 15 2015, 04:15 PM
jimkelly my buddy - rat rod charlie - is on his way to dayt... Oct 12 2015, 03:38 PM
jimkelly got me some doors coming via series9's shop. Oct 15 2015, 02:51 PM
jimkelly my head light question thread at this link... pics... Oct 16 2015, 12:00 PM
jimkelly decided that I will just put a delrin spacer here ... Oct 18 2015, 05:54 AM
jimkelly new doors coming home today. guess i'll put w... Oct 30 2015, 02:56 PM
flmont Jim,..how do U intend to run the water lines under... Oct 30 2015, 10:12 PM
jimkelly under - it is tried and true - but thru longs give... Oct 30 2015, 10:36 PM
rightpedal Jim I laugh every time I see the "pickup... Oct 31 2015, 05:16 AM
jimkelly white doors are back on my 1975 and red doors are ... Oct 31 2015, 04:37 PM
914forme And to think I just man handle doors in place, put... Oct 31 2015, 05:09 PM
jimkelly thank god I had the hoist... no way could I have i... Oct 31 2015, 06:50 PM
jimkelly yesterday I picked up a fuse box section and a fro... Nov 1 2015, 08:03 AM
mepstein Save your old fuse panel in case you or someone el... Nov 1 2015, 09:07 AM
jimkelly mark - that is awesome - I am so glad I got a kid ... Nov 1 2015, 09:23 AM
mark - that is awesome - I am so glad I got a kid... Nov 1 2015, 09:33 AM
jimkelly just stripped down the bumper. i'll be return... Nov 1 2015, 10:26 AM
jimkelly well, I still don't understand how you guys ac... Nov 7 2015, 08:27 AM
Andyrew
well, I still don't understand how you guys a... Nov 7 2015, 11:18 AM
mepstein Pm me your address and I'll send down some cli... Nov 7 2015, 08:49 AM
jimkelly mark, how about I visit next week, I need to bring... Nov 7 2015, 08:58 AM
mark, how about I visit next week, I need to brin... Nov 7 2015, 09:09 AM
jimkelly guess if I just remove lens, maybe I would have a ... Nov 7 2015, 11:46 AM
914forme Small bit and bit holder does the trick also, remo... Nov 7 2015, 02:03 PM
jimkelly (( driver bit in fingers seems like a decent solut... Nov 7 2015, 02:19 PM
jimkelly since i have been getting my lights and guages rei... Nov 9 2015, 04:37 PM
jimkelly it turns out that my car has dash wiring for EGR a... Nov 11 2015, 10:22 AM
jimkelly tested my buddy's theory that my battery charg... Nov 14 2015, 09:45 AM
jimkelly did a loose bolt/wire check and found 3 nuts at bo... Nov 15 2015, 05:39 PM
jimkelly got me some stuff from 914rubber :) Nov 25 2015, 09:41 PM
jimkelly did a little something on my 75 today. got some s... Nov 29 2015, 12:27 PM
jimkelly think i found my parts car, a lowly ej22 in need o... Mar 31 2016, 02:18 PM
matthepcat ^^That motor has a factory forged crank ^^
You ca... Mar 31 2016, 02:47 PM
jimkelly one step closer... with a 1990 subaru legacy awd..... Mar 31 2016, 08:26 PM
76-914
one step closer...
BUT NOT TO TURBO :D
time to... Apr 1 2016, 08:41 AM
jimkelly i'm concerned. i knew the engine has some iss... Apr 1 2016, 01:10 PM
zipedadoo What year is the subaru? I used a 1996 ej22. I fou... Apr 1 2016, 01:54 PM
jimkelly 1990 subaru legacy awd.. must have been sitting fo... Apr 1 2016, 02:29 PM
Chris H. No the car in that clip is a 4 cylinder turbo car.... Apr 1 2016, 10:21 PM
jimkelly all he said was that he stopped running it cause h... Apr 2 2016, 05:57 AM
jimkelly ok, engine runs but weak. seems spark is ok but n... Apr 6 2016, 06:45 AM
jimkelly got me second ej22 today $100. Apr 6 2016, 06:02 PM
Andyrew
You and you... Apr 12 2016, 03:34 PM
jimkelly my 1990 subaru legacy 5spd awd, pulling harness, t... Apr 12 2016, 03:06 PM
jimkelly thank you andy :D
at a gas station on the way b... Apr 12 2016, 04:11 PM
jimkelly great thread on repairing shielded suby wires.
htt... May 29 2016, 10:27 AM
jimkelly pulled engine and trans last night. made a cradle ... Jun 10 2016, 06:07 PM
76-914 The Fun begins Jim. :popcorn: You may need a few ... Jun 10 2016, 06:24 PM
jimkelly I have several wires to fix on my harness. someho... Jun 11 2016, 03:19 PM
I have several wires to fix on my harness. someh... Jun 11 2016, 03:43 PM
arkitect
Cool use of... Jun 10 2016, 10:37 PM
jimkelly thanks :)
got me second ej22 today $100.... Jun 11 2016, 03:16 PM
76-914
ambitious, no. :poke: poking myself :D
fruga... Jun 12 2016, 03:24 PM
frug... Jun 12 2016, 05:46 PM
rightpedal I might be able to help with the cradle. Want to ... Jun 12 2016, 07:00 PM
jimkelly I already have the suby cradle and trans hangers f... Jun 12 2016, 07:21 PM
jimkelly i bit off topic but i am making my recently bought... Jun 27 2016, 05:58 AM
jimkelly engine stand getting closer to finished and closer... Jul 1 2016, 09:10 PM
jimkelly latest of engine on stand... amnd video of harness... Jul 13 2016, 04:51 PM
jimkelly decided to try a microsquirt based on many youtube... Apr 5 2017, 06:15 AM
76-914 Good to see you haven't given up. MS is easier... Apr 5 2017, 07:59 AM
jimkelly guess i'll cross that bridge if i ever get the... Apr 5 2017, 10:46 AM
jpnovak MS2 ECU board fits nicely inside a stock Suby ECU ... Apr 5 2017, 02:48 PM![]() ![]() |
Lo-Fi Version | Time is now: 25th September 2026 - 12:01 PM |
