| bdstone914 |
Jun 19 2016, 07:10 AM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,427 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I have always found these to be a PITA to install. I have tried installing the rear bearings after freezing them and cant see any difference.
If expansion and contraction are proportional to the temperature then dry ice at -109 F should make a big difference. Used in combination of putting the 911 front hub in the oven at 250-300 degrees I am hoping the races will drop right in. Anyone tried it or have an easy method without the proper too size puller tools? |
| mgp4591 |
Jun 19 2016, 08:01 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,073 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region
I haven't changed mine out but every other German vehicle I've worked on has little gaps in the backside of the hubs behind the races - I take my punch and walk them out. My set of race install tools weren't that expensive either but then I was making my living with them so the expense was negligible. Before I bought them though, I'd take the old races and stack them on the new ones and gently tap them into place.
I'd think your idea of dry ice or just putting them in the freezer for hours will work fine. |
bdstone914 Installing bearing races in front hubs with dry ice or heat, Anyone try it? Jun 19 2016, 07:10 AM
stugray I have just driven the old ones out like mqp4591 e... Jun 19 2016, 08:10 AM
Valy Oven and freezer work great but you have to use a ... Jun 19 2016, 08:52 AM
Mueller Been awhile since i have done 914 wheel bearings, ... Jun 19 2016, 09:11 AM
toolguy Nothing beats getting them in smoothly than a litt... Jun 19 2016, 12:20 PM
bdstone914
Nothing beats getting them in smoothly than a lit... Jun 19 2016, 01:19 PM
76-914 Or the correct O.D. Harbor Freight impact socket a... Jun 19 2016, 12:37 PM
A&P Mech I just purchased new rotors and bearings from PMB,... Jun 19 2016, 04:30 PM
r_towle Did the 911 with hub on the stovetop and race in t... Jun 19 2016, 05:06 PM
Mark Henry
used old race to hammer in new race flush.
:ag... Jun 20 2016, 10:09 AM
veekry9 https://www.google.ca/search?q=induction+he...UTqA... Jun 19 2016, 06:43 PM
matthepcat For the rear bearings I found that you have to fre... Jun 20 2016, 09:03 AM![]() ![]() |
Lo-Fi Version | Time is now: 20th November 2026 - 08:55 AM |
