> This father needs help starting, Starter wont spin 1970 1.7 L
pgollender
post Jun 19 2016, 09:55 AM
All I really want for father's day is to spend a little time with my dad and to start my new motor. (IMG:style_emoticons/default/hissyfit.gif)
On the run stand:
Everything primed except oil. and the starter won't spin:
Here are the brushes:
Here is the armature/communicator:
Here is the casing/Bosch part ID:
When the brushes get this worn, will it not spin the armature ?
Can you just order the brush plate assembly ?
stugray
post Jun 19 2016, 10:45 AM
Does it spin if you apply voltage directly to the motor windings?
Does the solenoid kick it out?
If the solenoid kicks out does it apply voltage to the starter windings?
pgollender
post Jun 19 2016, 11:19 AM
QUOTE(stugray @ Jun 19 2016, 09:45 AM) *
Applying voltage on the bench to the solenoid kicks the armature out.
I didn't think to bypass the solenoid and apply voltage directly to the motor windings.
Or to see if I have no current past the solenoid.
So If motor runs when directly connected, then the Solenoid to motor connection is bad.
I will try that next.
Thanks !!!
- Lo-Fi Version Time is now: 1st August 2025 - 12:45 PM
