> Good deal on E-code headlights, Cibie E-code copy or Hella E-codes
Mark Henry
post Jun 27 2016, 10:10 AM
that's what I do!
Was going to mention this in the LED headlight thread but then thought it may be a hijack.
The BusDepot has good deals on the Cibie E-code copy ($35/pr) or Hella E-codes ($70/pr) plus bulbs.
http://www.busdepot.com/nl910ch4/
(IMG:http://www.914world.com/bbs2/uploads_offsite/cdn.busdepot.com-26-1467043928.1.jpg)
post Jun 28 2016, 12:02 PM
Can the standard 55/60 watt bulbs really be used without adding relays?
Mark Henry
post Jun 28 2016, 01:28 PM
that's what I do!
QUOTE(19732.0 @ Jun 28 2016, 02:02 PM) *
Yes, but anything bigger will need a relay(s).
Might be wrong but for the 90/100w I think you would need 4 SPDT 5-pin relays, 2 (hi-low) for each side. I'd get the 40amp relays and I would also get the matching sockets to make a clean install. You can get these at many FLAPS, off of amazon I think they're about $7ea with sockets. The relay must have five terminals labeled 85, 86, 30, 87, and 87a, these relays are a common bosch copy. If they are not marked with the numbers above they're likely the wrong relay.
Also note that bigger than the 55/60 is actually not DOT legal and I'd never use bigger than the 55/60 in a plastic light housing. I believe the ones in this thread are all glass or glass/metal.
Mark Henry   Good deal on E-code headlights   Jun 27 2016, 10:10 AM
rfinegan   I have Cebie E codes and they are AWESOME. Hardly ...   Jun 27 2016, 11:32 AM
Mark Henry   I have a set of real Cibie e codes but they have a...   Jun 27 2016, 11:35 AM
gandalf_025   I have a set of Cibe Z Beams that have been on my ...   Jun 27 2016, 03:35 PM
Minerva's 914   I carefully opened up my Cibe' set and sanded ...   Jun 27 2016, 06:49 PM
bandjoey   What's the difference in bulbs? Extra dollar ...   Jun 27 2016, 06:51 PM
larryM   What's the difference in bulbs? Extra dollar...   Jun 27 2016, 10:53 PM
Shadowfax   Thanks for the heads up. Ordered a pair of Hella E...   Jun 28 2016, 08:57 AM
maf914   :hijacked: Mark, Thanks for the heads up on the...   Jun 28 2016, 09:13 AM
green914   Thanks for sharing the info - looks like a very go...   Jun 28 2016, 09:56 AM
19732.0   Can the standard 55/60 watt bulbs really be used w...   Jun 28 2016, 12:02 PM
bandjoey   Can the standard 55/60 watt bulbs really be used ...   Jun 28 2016, 12:37 PM
Mark Henry   Can the standard 55/60 watt bulbs really be used ...   Jun 28 2016, 01:28 PM
bandjoey   I ordered the Hella set. Will post pics when they ...   Jun 28 2016, 09:11 PM
Mark Henry   On the relays, bit more expensive route but more c...   Jun 29 2016, 01:07 PM
toolguy   Note. . Oppps. . I thought we were talking about...   Jun 29 2016, 02:45 PM
eric9144   Don't forget the factory wiring is a single l...   Jun 29 2016, 02:57 PM
Cuda911   Thanks for the info, Mark, I just ordered two sets...   Jun 29 2016, 10:09 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 02:25 PM
