> Plastic Tunnel Fuel Lines, I want to replace the 2 tunnel fuel lines in my 76 - 914
matchpoint
post Jun 28 2016, 04:58 PM
I have my 76 - 914 engine and fuel tank out of my car during my frame off restoration. I want to replace the 2 plastic/nylon fuel lines in the tunnel with an OE product and not use the stainless or mild steal fuel line. I want to go back original and after 40 years of service I want to replace the plastic lines. Looks like everyone says go stainless but I want to go with the OE plastic.
Does anyone have a part number of a replacement plastic/nylon tubing of the same size as the OE plastic tubing. I think it is 7MM OD size. Auto Atlanta told me to just blow out the OE plastic lines and don't waste your time replacing. Looks like an easy replacement while the car is apart and all I need to know is a P/N of a plastic/nylon fuel tubing I can get @ NAPA.
Thanks
Catorse
post Jun 29 2016, 03:44 PM
They used asbestos for decades and lead for centuries. Just because it lasted doesn't mean it was the best material to use.
The plastic lines are a safety issue, plain and simple. Yes, I already replaced mine.
JeffBowlsby
post Jun 29 2016, 04:04 PM
QUOTE(Catorse @ Jun 29 2016, 02:44 PM) *
What basis do you have for that opinion other than anecdotal and is it a unilateral or conditional opinion?
Automotive engineers certainly had metal tubing available for fuel lines in the 1970s, they chose nylon intentionally and it met federal safety standards at the time of manufacture. Not saying they are not a maintenance item and may require replacement from time to time as good practice, but your unequivocal statement is not substantiated. I can think of a few disadvantages of metallic tubing over nonmetallic tubing for fuel lines, its not as slam-dunk as some think.
matchpoint   Plastic Tunnel Fuel Lines   Jun 28 2016, 04:58 PM
napasteve   I'm having a hard time understanding why you w...   Jun 28 2016, 05:19 PM
Jeff Bowlsby   OE fuel lines are NLA. The 1970-74 lines are nylo...   Jun 28 2016, 05:28 PM
OU812   Try the search function There is mucho info on i...   Jun 28 2016, 05:52 PM
914Sixer   Bel-Metric has the new version of the fuel line yo...   Jun 28 2016, 06:02 PM
mepstein   Makes sense not to use the best product available ...   Jun 28 2016, 06:10 PM
pete000   This is the one part I would not want "Factor...   Jun 28 2016, 06:20 PM
green914   Pelican Parts has the how to instructions for repl...   Jun 29 2016, 10:56 AM
JawjaPorsche   If I was making an investment like you are, why ta...   Jun 29 2016, 01:49 PM
Jeff Bowlsby   "Polyamide" is the larger family name fo...   Jun 29 2016, 01:54 PM
matchpoint   "Polyamide" is the larger family name f...   Jun 29 2016, 02:19 PM
barefoot   http://www.parker.com/literature/Parflex/B.../CAT%...   Jun 29 2016, 02:47 PM
Jeff Bowlsby   It will take some workmanship care and research to...   Jun 29 2016, 03:01 PM
Catorse   They used asbestos for decades and lead for centur...   Jun 29 2016, 03:44 PM
Jeff Bowlsby   The plastic lines are a safety issue, plain and s...   Jun 29 2016, 04:04 PM
mepstein   I would think the chance of it getting nicked by t...   Jun 29 2016, 05:01 PM
Mueller   Nylon tubing for fuel is approved for aircraft use...   Jun 29 2016, 05:08 PM
napasteve   Jeff, I just replaced my OE metal/plastic lines t...   Jun 29 2016, 05:11 PM
Catorse   Whoaa......are we saying the 914 has AIRCRAFT QUAL...   Jun 29 2016, 08:23 PM
mepstein   Whoaa......are we saying the 914 has AIRCRAFT QUA...   Jun 29 2016, 08:53 PM
John Jentz   Whoaa......are we saying the 914 has AIRCRAFT QUA...   Jun 30 2016, 09:35 AM
matchpoint   Whoaa......are we saying the 914 has AIRCRAFT QU...   Jun 30 2016, 10:14 AM
porschetub   Whoaa......are we saying the 914 has AIRCRAFT QU...   Jul 26 2016, 11:26 PM
Amphicar770   If you want to have original hoses because you thi...   Jun 29 2016, 08:26 PM
matchpoint   Three reasons Porsche may have used plastic fuel l...   Jun 29 2016, 09:09 PM
Jeff Bowlsby   We should not advocate for either the nylon or SS ...   Jun 29 2016, 10:30 PM
mbseto   Which is more durable against battery acid - I d...   Jun 30 2016, 08:46 AM
oakdalecurtis   Sorry to those who might have read this story in p...   Jul 26 2016, 12:22 PM
914_teener   :agree: The failure was the battery placement wh...   Jul 26 2016, 11:40 PM
veekry9   Old lines have ruined a few 914s,so,a rigorous ...   Jul 27 2016, 03:16 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:00 PM
