Converting from Fuel Injection to Carbs, Need Fuel Distrabution help |
Robin914-4 |
Nov 28 2015, 12:06 PM
Newbie Group: Members Posts: 10 Joined: 28-November 15 From: Statesboro, Georgia Member No.: 19,419 Region Association: South East States |
Hey Everybody. I have been searching for an hour with no luck. I have a 1976 914/4 that I have converted over to 44mm Empi's. Now I am setting up the fuel system, new low pressure pump, stainless lines, presure regulator, etc. what I can't figure out is what to do with the extra line I have on the fuel tank. Should I cap it? Vent it? I did run both stainless line back to the engine bay so I could t them in or what ever. I just need some guidance.
Thanks in advance. Robin |
Perry Kiehl Clone |
Jun 30 2016, 02:00 PM
Unregistered |
Not meant to insult, but if you got a set of carbs for $75, I'm betting you'll have a bunch of trouble. You may have gotten lucky, or you may have gotten someone else's problems. A mild bump in displacement won't really be a problem with the FI system. You may need to dial it in with a wide band O2 sensor, but it should work fine. All of the advice you are getting to keep the FI is with and for good reason.
Lo-Fi Version | Time is now: 9th June 2024 - 06:51 PM |
