| Keith914 |
Jul 1 2016, 04:30 PM
Member ![]() ![]() Group: Members Posts: 248 Joined: 29-April 16 From: Laguna Beach, California 92651 Member No.: 19,948 Region Association: Southern California |
I have installed a new 19mm master cylinder that came with a single switch. My '72 harness to this switch has two wires each with a female "push on" connector, but the new brake master cylinder switch has only one male connector on it, next to the reset (?) switch. Two questions: 1) do I need to find a two connector switch, and 2) how do you reset the switch? I pushed the little black button into the switch and I think a felt it go in with a slight "snap".
| BeatNavy |
Jul 1 2016, 04:59 PM
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,962 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region
The old MC switches grounded with the brown wire on your wiring harness. The new switch grounds through the MC itself. Just tape up the brown wire on your harness - you don't need it with the new MC.
That switch you pushed should be the reset switch. |
| Keith914 |
Jul 4 2016, 09:34 AM
The old MC switches grounded with the brown wire on your wiring harness. The new switch grounds through the MC itself. Just tape up the brown wire on your harness - you don't need it with the new MC. That switch you pushed should be the reset switch. Have now thoroughly checked the emergency brake switch condition and setting -- all OK. What should I try next? |
Keith914 Master cylinder switch and reset. Jul 1 2016, 04:30 PM
Keith914
The old MC switches grounded with the brown wire ... Jul 2 2016, 12:54 PM
Keith914 Thanks for your prompt helpful response. I will re... Jul 1 2016, 06:13 PM
Keith914
Thanks for your prompt helpful response. I will r... Jul 2 2016, 11:07 AM
era vulgaris Are you talking about the blinking light that... Jul 2 2016, 11:43 AM
Larmo63 :agree: Jul 2 2016, 12:11 PM
Dave_Darling That thing you describe may be a diode to keep the... Jul 2 2016, 01:25 PM
Keith914
That thing you describe may be a diode to keep th... Jul 2 2016, 06:16 PM
Keith914
That thing you describe may be a diode to keep th... Jul 5 2016, 08:02 PM
BeatNavy Stupid question, but does the brake system need to... Jul 2 2016, 01:53 PM
Keith914
Stupid question, but does the brake system need t... Jul 3 2016, 09:21 AM
BeatNavy
Stupid question, but does the brake system need ... Jul 4 2016, 01:41 PM
Keith914 Not a stupid question. Along with replacing the ma... Jul 2 2016, 02:08 PM
Keith914 Yes a PITA! Any suggestions where I can buy on... Jul 4 2016, 03:56 PM
BeatNavy
Yes a PITA! Any suggestions where I can buy o... Jul 4 2016, 04:43 PM
Keith914
Yes a PITA! Any suggestions where I can buy ... Jul 5 2016, 09:45 AM
worn
[quote name='BeatNavy' post='2367475' date='Jul 4... Jul 5 2016, 10:37 AM
Dave_Darling Find what is grounded. Is the MC switch providing... Jul 4 2016, 10:40 PM
BeatNavy That's progress, I think. I would rather trac... Jul 5 2016, 10:04 AM
Keith914
That's progress, I think. I would rather tra... Jul 5 2016, 12:21 PM
Keith914 Mine is a '72. I don't have a brake fluid ... Jul 5 2016, 12:28 PM
Keith914 Looks like I found the problem. Earlier in this st... Jul 6 2016, 12:09 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:53 PM |
