> Master cylinder switch and reset.
Keith914
post Jul 1 2016, 04:30 PM
I have installed a new 19mm master cylinder that came with a single switch. My '72 harness to this switch has two wires each with a female "push on" connector, but the new brake master cylinder switch has only one male connector on it, next to the reset (?) switch. Two questions: 1) do I need to find a two connector switch, and 2) how do you reset the switch? I pushed the little black button into the switch and I think a felt it go in with a slight "snap".
Keith914
post Jul 4 2016, 03:56 PM
Yes a PITA! Any suggestions where I can buy one?
Further, also just tested my refurbished fuel delivery system with Tangerine SS tunnel pipe. All buttoned up, switched the ignition on, hear pump running, then smell gas. New in line (with T connection) fuel pressure gauge spewing gas, WTF. Removed the gauge, opened it up. Sure enough the solder connection expanding copper tube to brass base leaking!! Need a different brand 15p.s.i. gauge (carbs).
BeatNavy
post Jul 4 2016, 04:43 PM
QUOTE(Keith914 @ Jul 4 2016, 05:56 PM) *
One step forward, two steps backward, eh? Hang in there.
This is the only switch I saw, but I'm not 100% sure this is what you need for your application: https://europortparts.com/sku/90161311500.1...CFcYfhgodpSwN9g
May want to ask Eric at PMB.
Keith914   Master cylinder switch and reset.   Jul 1 2016, 04:30 PM
BeatNavy   The old MC switches grounded with the brown wire o...   Jul 1 2016, 04:59 PM
Keith914   The old MC switches grounded with the brown wire ...   Jul 2 2016, 12:54 PM
Keith914   The old MC switches grounded with the brown wire ...   Jul 4 2016, 09:34 AM
Keith914   Thanks for your prompt helpful response. I will re...   Jul 1 2016, 06:13 PM
Keith914   Thanks for your prompt helpful response. I will r...   Jul 2 2016, 11:07 AM
era vulgaris   Are you talking about the blinking light that...   Jul 2 2016, 11:43 AM
Larmo63   :agree:   Jul 2 2016, 12:11 PM
Dave_Darling   That thing you describe may be a diode to keep the...   Jul 2 2016, 01:25 PM
Keith914   That thing you describe may be a diode to keep th...   Jul 2 2016, 06:16 PM
Keith914   That thing you describe may be a diode to keep th...   Jul 5 2016, 08:02 PM
BeatNavy   Stupid question, but does the brake system need to...   Jul 2 2016, 01:53 PM
Keith914   Stupid question, but does the brake system need t...   Jul 3 2016, 09:21 AM
BeatNavy   Stupid question, but does the brake system need ...   Jul 4 2016, 01:41 PM
Keith914   Not a stupid question. Along with replacing the ma...   Jul 2 2016, 02:08 PM
Keith914   Yes a PITA! Any suggestions where I can buy on...   Jul 4 2016, 03:56 PM
BeatNavy   Yes a PITA! Any suggestions where I can buy o...   Jul 4 2016, 04:43 PM
Keith914   Yes a PITA! Any suggestions where I can buy ...   Jul 5 2016, 09:45 AM
worn   [quote name='BeatNavy' post='2367475' date='Jul 4...   Jul 5 2016, 10:37 AM
Dave_Darling   Find what is grounded. Is the MC switch providing...   Jul 4 2016, 10:40 PM
BeatNavy   That's progress, I think. I would rather trac...   Jul 5 2016, 10:04 AM
Keith914   That's progress, I think. I would rather tra...   Jul 5 2016, 12:21 PM
Keith914   Mine is a '72. I don't have a brake fluid ...   Jul 5 2016, 12:28 PM
Keith914   Looks like I found the problem. Earlier in this st...   Jul 6 2016, 12:09 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 02:53 PM
