> Master cylinder switch and reset.
Keith914
post Jul 1 2016, 04:30 PM
I have installed a new 19mm master cylinder that came with a single switch. My '72 harness to this switch has two wires each with a female "push on" connector, but the new brake master cylinder switch has only one male connector on it, next to the reset (?) switch. Two questions: 1) do I need to find a two connector switch, and 2) how do you reset the switch? I pushed the little black button into the switch and I think a felt it go in with a slight "snap".
BeatNavy
post Jul 5 2016, 10:04 AM
That's progress, I think. I would rather trace the wiring and try to find the offending ground than deal with a faulty MC or MC switch. It's really only two wires, and one of them is inadvertently grounded.
How did you check the E-brake switch? I would pull that thing out, inspect it, and then check continuity from that wire to ground. That little switch gets a little abused due to its use/location and may have failed.
Keith914   Master cylinder switch and reset.   Jul 1 2016, 04:30 PM
BeatNavy   The old MC switches grounded with the brown wire o...   Jul 1 2016, 04:59 PM
Keith914   The old MC switches grounded with the brown wire ...   Jul 2 2016, 12:54 PM
Keith914   The old MC switches grounded with the brown wire ...   Jul 4 2016, 09:34 AM
Keith914   Thanks for your prompt helpful response. I will re...   Jul 1 2016, 06:13 PM
Keith914   Thanks for your prompt helpful response. I will r...   Jul 2 2016, 11:07 AM
era vulgaris   Are you talking about the blinking light that...   Jul 2 2016, 11:43 AM
Larmo63   :agree:   Jul 2 2016, 12:11 PM
Dave_Darling   That thing you describe may be a diode to keep the...   Jul 2 2016, 01:25 PM
Keith914   That thing you describe may be a diode to keep th...   Jul 2 2016, 06:16 PM
Keith914   That thing you describe may be a diode to keep th...   Jul 5 2016, 08:02 PM
BeatNavy   Stupid question, but does the brake system need to...   Jul 2 2016, 01:53 PM
Keith914   Stupid question, but does the brake system need t...   Jul 3 2016, 09:21 AM
BeatNavy   Stupid question, but does the brake system need ...   Jul 4 2016, 01:41 PM
Keith914   Not a stupid question. Along with replacing the ma...   Jul 2 2016, 02:08 PM
Keith914   Yes a PITA! Any suggestions where I can buy on...   Jul 4 2016, 03:56 PM
BeatNavy   Yes a PITA! Any suggestions where I can buy o...   Jul 4 2016, 04:43 PM
Keith914   Yes a PITA! Any suggestions where I can buy ...   Jul 5 2016, 09:45 AM
worn   [quote name='BeatNavy' post='2367475' date='Jul 4...   Jul 5 2016, 10:37 AM
Dave_Darling   Find what is grounded. Is the MC switch providing...   Jul 4 2016, 10:40 PM
BeatNavy   That's progress, I think. I would rather trac...   Jul 5 2016, 10:04 AM
Keith914   That's progress, I think. I would rather tra...   Jul 5 2016, 12:21 PM
Keith914   Mine is a '72. I don't have a brake fluid ...   Jul 5 2016, 12:28 PM
Keith914   Looks like I found the problem. Earlier in this st...   Jul 6 2016, 12:09 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 02:53 PM
