> Master cylinder switch and reset.
Keith914
post Jul 1 2016, 04:30 PM
I have installed a new 19mm master cylinder that came with a single switch. My '72 harness to this switch has two wires each with a female "push on" connector, but the new brake master cylinder switch has only one male connector on it, next to the reset (?) switch. Two questions: 1) do I need to find a two connector switch, and 2) how do you reset the switch? I pushed the little black button into the switch and I think a felt it go in with a slight "snap".
Dave_Darling
post Jul 2 2016, 01:25 PM
914 Idiot
That thing you describe may be a diode to keep the power from going "backwards" through the system.
The blinking light in the combo gauge will blink when the key is on and EITHER the handbrake handle is up and not pressing on the handbrake handle switch, OR the master cylinder switch is closed.
If the wire going to either of those switches is shorted to ground, the light will also flash.
--DD
Keith914
post Jul 5 2016, 08:02 PM
QUOTE(Dave_Darling @ Jul 2 2016, 12:25 PM) *
--DD
Do you know if the "diode"described above is stock?
Keith914   Master cylinder switch and reset.   Jul 1 2016, 04:30 PM
BeatNavy   The old MC switches grounded with the brown wire o...   Jul 1 2016, 04:59 PM
Keith914   The old MC switches grounded with the brown wire ...   Jul 2 2016, 12:54 PM
Keith914   The old MC switches grounded with the brown wire ...   Jul 4 2016, 09:34 AM
Keith914   Thanks for your prompt helpful response. I will re...   Jul 1 2016, 06:13 PM
Keith914   Thanks for your prompt helpful response. I will r...   Jul 2 2016, 11:07 AM
era vulgaris   Are you talking about the blinking light that...   Jul 2 2016, 11:43 AM
Larmo63   :agree:   Jul 2 2016, 12:11 PM
Dave_Darling   That thing you describe may be a diode to keep the...   Jul 2 2016, 01:25 PM
Keith914   That thing you describe may be a diode to keep th...   Jul 2 2016, 06:16 PM
Keith914   That thing you describe may be a diode to keep th...   Jul 5 2016, 08:02 PM
BeatNavy   Stupid question, but does the brake system need to...   Jul 2 2016, 01:53 PM
Keith914   Stupid question, but does the brake system need t...   Jul 3 2016, 09:21 AM
BeatNavy   Stupid question, but does the brake system need ...   Jul 4 2016, 01:41 PM
Keith914   Not a stupid question. Along with replacing the ma...   Jul 2 2016, 02:08 PM
Keith914   Yes a PITA! Any suggestions where I can buy on...   Jul 4 2016, 03:56 PM
BeatNavy   Yes a PITA! Any suggestions where I can buy o...   Jul 4 2016, 04:43 PM
Keith914   Yes a PITA! Any suggestions where I can buy ...   Jul 5 2016, 09:45 AM
worn   [quote name='BeatNavy' post='2367475' date='Jul 4...   Jul 5 2016, 10:37 AM
Dave_Darling   Find what is grounded. Is the MC switch providing...   Jul 4 2016, 10:40 PM
BeatNavy   That's progress, I think. I would rather trac...   Jul 5 2016, 10:04 AM
Keith914   That's progress, I think. I would rather tra...   Jul 5 2016, 12:21 PM
Keith914   Mine is a '72. I don't have a brake fluid ...   Jul 5 2016, 12:28 PM
Keith914   Looks like I found the problem. Earlier in this st...   Jul 6 2016, 12:09 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:08 PM
