Mockmaw |
Member ![]() ![]() Group: Members Posts: 163 Joined: 18-March 03 From: Berkeley/San Diego, CA Member No.: 438 ![]() |
It's a very sad day for me and my Porsche.. something is very, very wrong.
The engine is running poorly, it's smoking, and it's making a strange flapping noise.. I talked about this a few weeks ago. We've since determined that there's a 'leak' between the cylinder and the cylinder head that's spitting oil and compressed air. The fact that there's compression leads me to believe that the connecting rod is still good. I'm stumped and I'm frustrated, so I need some help: What could be the problem? What can I do to help pinpoint what's happening? The fact that there's compression leads me to believe that the connecting rod is okay. Is the cylinder head warped? The cylinder? Grr.. I just put money into engine work and a week later this happens.. the pessimist side of me wants to say that the two are connected, but it's probably just the standard mechanical failure that happens to 30 year old cars. So what do I do next? What are my options? The car's in SD and I'm in the Bay Area working fulltime and doing summer school.. which means I'll have plenty of time to research things but little time to actually work on the car. All for now, thanks in advance for the help, I'll keep posting as I discover new things. Feel free to ask questions of clarification and such. Edit: Forgot to mention, it's the #1 cylinder. -Tyler |
need4speed |
Member ![]() ![]() Group: Members Posts: 339 Joined: 11-April 03 From: Arroyo Grande, CA Member No.: 564 ![]() |
Well, if oil seals and cooler were replaced, it could be that one of them is loose and that's where you're leaking oil -
which could lead to: improper cooling which could lead to: warped head, loose stud, etc. just about every truly catastrophic thing that could cause a cylinder leak. Or, the MPS could be running the car too lean, which could lead to improper cooling. . . (ie. make sure the car isn't running hot - but I guess it's too late for that now). So, compression was "good" in all 4 cylinders? If one was leaking, then compression could still be good in the other three. . . |
Lo-Fi Version | Time is now: 12th July 2025 - 04:00 PM |
