Rear Trailing Arms, Reinforcements to Resist Twisting |
Heater Guy |
May 6 2016, 10:00 PM
Member Group: Members Posts: 74 Joined: 20-October 09 From: Walnut Creek, CA Member No.: 10,960 Region Association: Northern California |
Lamont Welding & Fabrication in Antioch, CA (925) 754-7824 has a fixture to modify trailing arms. It holds the trailing arm in the correct stock alignment.
He mounts the trailing arm in the fixture, cuts it in half and welds in a 1/8" rectangular plate. The 1/8" plate helps to reduce twisting deformation by breaking the twisting length of the arm into two lengths instead of one long length. The charge is $80.00 per trailing arm. I just had my trailing arms reinforced. This reinforcing method is better than plating the arms with heavy sheet metal. |
old914dog |
May 10 2016, 08:58 AM
Member Group: Members Posts: 72 Joined: 28-August 04 From: dallas,tx Member No.: 2,643 Region Association: None |
Brant and Chris,
Since Vintage racing does not allow "cage to suspension pick-up points," what is your opinion on the inner ear reinforcement which goes forward to the lower firewall. Can be welded or bolt-in as small radius rod. I also think the inner ear problems are partially due to the outer ear becoming loose or ?? Please opine for us vintage cars and more vintage drivers!! |
brant |
May 10 2016, 03:29 PM
914 Wizard Group: Members Posts: 11,632 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Brant and Chris, Since Vintage racing does not allow "cage to suspension pick-up points," what is your opinion on the inner ear reinforcement which goes forward to the lower firewall. Can be welded or bolt-in as small radius rod. I also think the inner ear problems are partially due to the outer ear becoming loose or ?? Please opine for us vintage cars and more vintage drivers!! I depends on the specific rules of each club my club allows bolt in reinforcements, but not weld in reinforcements I run bolt in console braces on both of the 914 race cars I've built I ripped out 2 suspension consoles within about a year, before adding my first bolt in reinforcement I consider it mandatory prior to reinforcement the trailing arm shaft lock nuts would be loose each and every day the car was tracked. it was a daily ritual to re-torque these and would lead to a tear if not tightened. since adding the reinforcements I haven't had a shaft nut come loose in 15 years. I believe a cage to the suspension points would make the car handle better but arm bolt in reinforcements make it not tear itself apart brant |
Han Solo |
Jul 12 2016, 02:15 PM
Member Group: Members Posts: 288 Joined: 30-September 13 From: Middle Tennessee Member No.: 16,456 Region Association: South East States |
prior to reinforcement the trailing arm shaft lock nuts would be loose each and every day the car was tracked. it was a daily ritual to re-torque these and would lead to a tear if not tightened. since adding the reinforcements I haven't had a shaft nut come loose in 15 years. brant I've noticed the same loosening on passenger side shaft at every autocross. Now tightening that is a ritual for me. That side has extensive long repairs so there's probably all kinds of flex going on. I really like JP's fix above (IMG:style_emoticons/default/agree.gif) That may be something I do this winter. That is... if I'm not too wrapped up in a 924S FP car build. |
Lo-Fi Version | Time is now: 3rd June 2024 - 06:37 AM |
