| djway |
Jul 12 2016, 04:49 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 787 Joined: 16-October 15 From: Riverside Member No.: 19,266 Region Association: Southern California |
I have a bad head temperature sensor on my 1974 1.8 914. I called Pelican Parts and they say they are not available. My car is just dumping fuel and I cant drive it until I get a new one.
Where can I find them? Thanks Dwayne |
| djway |
Jul 13 2016, 04:51 PM
Well, I ordered under that new part number and guess what, not available.
I finally talked to someone that actually knew about the problem at the Bus Depot. He was baffled about what to do. Every single type 1,2,3,4 aircooled and some watercooled with fuel injection use that same exact sensor. |
djway 1.8 CHT sensor Jul 12 2016, 04:49 PM
Dave_Darling The D-jet ones should work, at least to some exten... Jul 12 2016, 04:55 PM
djway
The D-jet ones should work, at least to some exte... Jul 12 2016, 05:04 PM
Big Len Does this help?
It's.....gulp, Auto Atlanta ... Jul 12 2016, 05:26 PM
djway
Does this help?
It's.....gulp, Auto Atlanta... Jul 12 2016, 05:57 PM
The Cabinetmaker http://www.bughaus.com/type_4_fuel_injectors_and_s... Jul 12 2016, 05:51 PM
djway
http://www.bughaus.com/type_4_fuel_injectors_and_... Jul 12 2016, 05:58 PM
jim_hoyland Try a VW shop that's servicing buses....virtua... Jul 12 2016, 06:40 PM
914Sixer What is the part #? The bughaus page is showing ... Jul 12 2016, 06:42 PM
djway
What is the part #? The bughaus page is showing... Jul 12 2016, 09:22 PM
MarkV http://www.ebay.com/itm/Porsche-Sensor-Cyl...kex... Jul 12 2016, 11:46 PM
djway
http://www.ebay.com/itm/Porsche-Sensor-Cyl...kex... Jul 13 2016, 03:23 AM
RohJay
[quote name='MarkV' post='2370833' date='Jul 12 2... Jul 14 2016, 12:14 AM
saigon71
[quote name='MarkV' post='2370833' date='Jul 12 ... Jul 14 2016, 07:02 AM
jcd914 Not to say that you don't need a CHT sensor bu... Jul 13 2016, 12:45 AM
djway
Not to say that you don't need a CHT sensor b... Jul 13 2016, 03:22 AM
djway
I have a bad head temperature sensor on my 1974 1... Jul 13 2016, 12:46 AM
The Cabinetmaker
After hours of searching I finally found a place ... Jul 15 2016, 04:51 PM
914Sixer I do not understand what happened to all the senso... Jul 13 2016, 08:37 PM
Keith914 I have one recently removed from my '72, Yours... Jul 13 2016, 08:56 PM
McMark $30 I'll send you one of my custom ones t... Jul 13 2016, 09:46 PM
djway
$30 I'll send you one of my custom ones ... Jul 13 2016, 11:31 PM
Mikey914
$30 I'll send you one of my custom ones ... Jul 14 2016, 12:24 AM
djway
$30 I'll send you one of my custom ones ... Jul 17 2016, 01:11 AM
jim_hoyland See:. http://www.ratwell.com/technical/TempSensorI... Jul 14 2016, 06:31 PM
McMark The stock sensor is some spring based variable res... Jul 15 2016, 08:24 AM
Mueller
The stock sensor is some spring based variable re... Jul 15 2016, 09:09 AM
McMark Hey Mark,
Can this sensor be used with Megasquir... Jul 15 2016, 10:34 AM
djway
The stock sensor is some spring based variable re... Jul 15 2016, 11:52 AM
Jeff Bowlsby
Which reminds me, I'd need core sensors to bu... Jul 17 2016, 08:53 AM
McMark Which reminds me, I'd need core sensors to bui... Jul 17 2016, 09:27 AM
stugray
M10x1.00 bolts aren't easy to find, although... Jul 17 2016, 11:25 AM
stugray connect the sensor wire to the input of a switch w... Jul 15 2016, 10:02 AM
Marty Yeoman I like the way you think. Jul 15 2016, 10:18 AM
djway Since I have your attention :) After putting in ... Jul 15 2016, 12:12 PM
catsltd
Since I have your attention :) After putting in... Jul 15 2016, 01:55 PM
76-914 I'm of no help as I don't know LJet but I ... Jul 15 2016, 02:26 PM
914_teener
I'm of no help as I don't know LJet but I... Jul 15 2016, 03:18 PM
djway
I'm of no help as I don't know LJet but ... Jul 15 2016, 03:54 PM
914_teener
[quote name='914_teener' post='2371901' date='Jul... Jul 15 2016, 04:58 PM
djway
I'm of no help as I don't know LJet but I... Jul 15 2016, 03:53 PM
McMark Worked from 7am to 10:30pm yesterday. Just replie... Jul 17 2016, 07:55 AM
catsltd
Worked from 7am to 10:30pm yesterday. Just repli... Jul 17 2016, 08:16 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:27 PM |
