| tornik550 |
Jul 13 2016, 03:10 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I have a freshly built 2.7l with 9.5:1 compression pistons. I currently have zenith 40 tin carbs with 34mm venturi's. The engine runs very well however I stumbled upon a nice set of weber 40 IDA's. I am much more familiar with weber carbs so I purchased them.
What would a good starting point for the following be? venturis idle jets main jets emulsion tubes air correction jets Also, are weber idf jets and vents interchangable with 3BBL IDA's? Thank you |
| tornik550 |
Jul 13 2016, 06:24 PM
Next question- Where can I find 34mm venturis?
tornik550 Weber 40 IDA 3bbl jet starting point for a 2.7 /6 Jul 13 2016, 03:10 PM
mskala I won't speculate on your settings as I have a... Jul 13 2016, 03:40 PM
Perry Kiehl Clone Jetting shouldn't be that different from the Z... Jul 13 2016, 05:11 PM
Luke M Here's a good chart with some starting points ... Jul 13 2016, 05:22 PM
Mark Henry
... Jul 13 2016, 06:58 PM
6freak
Next question- Where can I find 34mm venturis?... Jul 14 2016, 03:12 PM
Mark Henry
[quote name='Mark Henry' post='2371143' date='Jul... Jul 14 2016, 03:22 PM
tornik550
[quote name='Mark Henry' post='2371143' date='Ju... Jul 14 2016, 03:47 PM
6freak
[quote name='Mark Henry' post='2371143' date='Ju... Jul 15 2016, 03:24 PM
6freak
[quote name='Mark Henry' post='2371471' date='Jul... Jul 15 2016, 03:27 PM
Mark Henry The most valuable tool for jetting your carbs is a... Jul 14 2016, 04:25 PM
JmuRiz I plan on running an O2 sensor in mine too, gives ... Jul 14 2016, 05:43 PM
Mark Henry
I plan on running an O2 sensor in mine too, gives... Jul 14 2016, 06:21 PM
GeorgeRud I'd imagine a bung for each cylinder would be ... Jul 14 2016, 05:55 PM
tornik550 Does anyone know if Weber IDF velocity stacks will... Jul 14 2016, 06:49 PM
Mark Henry Measure the ID and the hole spacing center to cent... Jul 14 2016, 06:56 PM
Perry Kiehl Clone Mark speaks the truth on the O2 sensor. It makes ... Jul 14 2016, 09:37 PM
Mark Henry I have a good O2 meter and I put it on every car I... Jul 15 2016, 12:18 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:24 AM |
