> Weber 40 IDA 3bbl jet starting point for a 2.7 /6
tornik550
post Jul 13 2016, 03:10 PM
I have a freshly built 2.7l with 9.5:1 compression pistons. I currently have zenith 40 tin carbs with 34mm venturi's. The engine runs very well however I stumbled upon a nice set of weber 40 IDA's. I am much more familiar with weber carbs so I purchased them.
What would a good starting point for the following be?
venturis
idle jets
main jets
emulsion tubes
air correction jets
Also, are weber idf jets and vents interchangable with 3BBL IDA's?
Thank you
tornik550
post Jul 13 2016, 06:24 PM
Next question- Where can I find 34mm venturis?
Mark Henry
post Jul 13 2016, 06:58 PM
that's what I do!
QUOTE(tornik550 @ Jul 13 2016, 08:24 PM) *
http://youroil.net/weber_carb_parts.html
tornik550   Weber 40 IDA 3bbl jet starting point for a 2.7 /6   Jul 13 2016, 03:10 PM
mskala   I won't speculate on your settings as I have a...   Jul 13 2016, 03:40 PM
Perry Kiehl Clone   Jetting shouldn't be that different from the Z...   Jul 13 2016, 05:11 PM
Luke M   Here's a good chart with some starting points ...   Jul 13 2016, 05:22 PM
tornik550   Next question- Where can I find 34mm venturis?   Jul 13 2016, 06:24 PM
Mark Henry   Next question- Where can I find 34mm venturis? ...   Jul 13 2016, 06:58 PM
6freak   Next question- Where can I find 34mm venturis?...   Jul 14 2016, 03:12 PM
Mark Henry   [quote name='Mark Henry' post='2371143' date='Jul...   Jul 14 2016, 03:22 PM
tornik550   [quote name='Mark Henry' post='2371143' date='Ju...   Jul 14 2016, 03:47 PM
6freak   [quote name='Mark Henry' post='2371143' date='Ju...   Jul 15 2016, 03:24 PM
6freak   [quote name='Mark Henry' post='2371471' date='Jul...   Jul 15 2016, 03:27 PM
Mark Henry   The most valuable tool for jetting your carbs is a...   Jul 14 2016, 04:25 PM
JmuRiz   I plan on running an O2 sensor in mine too, gives ...   Jul 14 2016, 05:43 PM
Mark Henry   I plan on running an O2 sensor in mine too, gives...   Jul 14 2016, 06:21 PM
GeorgeRud   I'd imagine a bung for each cylinder would be ...   Jul 14 2016, 05:55 PM
tornik550   Does anyone know if Weber IDF velocity stacks will...   Jul 14 2016, 06:49 PM
Mark Henry   Measure the ID and the hole spacing center to cent...   Jul 14 2016, 06:56 PM
Perry Kiehl Clone   Mark speaks the truth on the O2 sensor. It makes ...   Jul 14 2016, 09:37 PM
Mark Henry   I have a good O2 meter and I put it on every car I...   Jul 15 2016, 12:18 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 10:26 AM
