> Do I have everything I need for a rear main seal replacement?
era vulgaris
post Jul 14 2016, 03:41 PM
J is for Genius
Decided to replace my RMS myself. First time I've pulled a trans, so I want to make sure I have everything I need before I start.
- 12 point triple square bit for CV bolts
- Flywheel lock
- clutch alignment tool
- Sabo RMS
- Flywheel o ring
- felt washer
- crush washer
- new CV gaskets
- new schnorr washers for CV bolts
Should I get a new pilot bearing? My engine and trans only have about 15,000 miles on them.
Anything to do with the clutch fork that needs to be taken care of when the trans is removed?
Is there anything else I'll need? Can all other bolts and washers be re-used?
Mark Henry
post Jul 14 2016, 04:27 PM
that's what I do!
Pilot bearing is only a few bucks and easy to do. (IMG:style_emoticons/default/shades.gif)
era vulgaris   Do I have everything I need for a rear main seal replacement?   Jul 14 2016, 03:41 PM
brant   I like to have the shifting fork cup (where the fo...   Jul 14 2016, 03:54 PM
rhodyguy   Throw out arm pivot bushing. The 2 plastic clips t...   Jul 14 2016, 03:58 PM
Mark Henry   Pilot bearing is only a few bucks and easy to do. ...   Jul 14 2016, 04:27 PM
era vulgaris   Awesome, thanks guys. So, added to the list... -...   Jul 14 2016, 06:19 PM
era vulgaris   Also in my searches I read somewhere that the clut...   Jul 14 2016, 06:20 PM
wndsrfr   Also in my searches I read somewhere that the clu...   Jul 14 2016, 08:07 PM
76-914   Since this is your 1st time; 1, there is a bolt on...   Jul 14 2016, 06:30 PM
era vulgaris   Since this is your 1st time; 1, there is a bolt o...   Jul 14 2016, 06:58 PM
Mark Henry   You can do it by eyeball, a proper size dowel, or ...   Jul 14 2016, 06:36 PM
rhodyguy   Those are the parts I mentioned. I forgot the fork...   Jul 14 2016, 06:40 PM
saigon71   Decided to replace my RMS myself. First time I...   Jul 14 2016, 06:46 PM
era vulgaris   When you mention "crush washer" are yo...   Jul 14 2016, 06:56 PM
saigon71   When you mention "crush washer" are y...   Jul 14 2016, 07:56 PM
era vulgaris   Alright, all parts have been ordered. Thanks so m...   Jul 15 2016, 11:00 AM
jrblackbox   case of beer? just sayin.   Jul 15 2016, 12:47 PM
era vulgaris   case of beer? just sayin. That's always in ...   Jul 15 2016, 02:13 PM
catsltd   I just did mine,well still doing. Good Luck. If y...   Jul 15 2016, 01:44 PM
era vulgaris   I just did mine,well still doing. Good Luck. If ...   Jul 15 2016, 02:19 PM
catsltd   I just did mine,well still doing. Good Luck. If...   Jul 15 2016, 09:41 PM
- Lo-Fi Version Time is now: 4th July 2025 - 06:50 AM
