> Do I have everything I need for a rear main seal replacement?
era vulgaris
post Jul 14 2016, 03:41 PM
J is for Genius
Decided to replace my RMS myself. First time I've pulled a trans, so I want to make sure I have everything I need before I start.
- 12 point triple square bit for CV bolts
- Flywheel lock
- clutch alignment tool
- Sabo RMS
- Flywheel o ring
- felt washer
- crush washer
- new CV gaskets
- new schnorr washers for CV bolts
Should I get a new pilot bearing? My engine and trans only have about 15,000 miles on them.
Anything to do with the clutch fork that needs to be taken care of when the trans is removed?
Is there anything else I'll need? Can all other bolts and washers be re-used?
post Jul 14 2016, 06:30 PM
Since this is your 1st time; 1, there is a bolt on top left side that is easy if you have a friend. If not you'll set a closed end wrench on the bolt head from the engine side or the nut on the tranny side will not come off. 2, the tranny might want to stick to the engine when you try to remove it. Maybe not. But if it does just man handle it and rock it about a wee bit. BE SURE that the rear of the engine is properly supported before you begin yanking on the tranny. Take a ton of pic's. You might need them to refer to later on. 3, mark or measure where the nuts are on the clutch cable. It will save you several trips back under the car. 4, take yer time aligning the disc. If it's a new one slide it upon the pilot shaft before installing to be sure it fits. Don't forget to clean out the allen head screws on your CV's before trying to remove them or you'll strip one. 5, talking to ones self is allowed and don't forget to have fun. (IMG:style_emoticons/default/beerchug.gif) Kent
era vulgaris
post Jul 14 2016, 06:58 PM
J is for Genius
QUOTE(76-914 @ Jul 14 2016, 08:30 PM) *
I think I read about that bolt. It's the top mounting bolt for the starter, right?
#5 will for sure be happening. And I can probably guarantee that a solid 70% of what a say to myself will be swear words directed at the car!! (IMG:style_emoticons/default/biggrin.gif)
era vulgaris   Do I have everything I need for a rear main seal replacement?   Jul 14 2016, 03:41 PM
brant   I like to have the shifting fork cup (where the fo...   Jul 14 2016, 03:54 PM
rhodyguy   Throw out arm pivot bushing. The 2 plastic clips t...   Jul 14 2016, 03:58 PM
Mark Henry   Pilot bearing is only a few bucks and easy to do. ...   Jul 14 2016, 04:27 PM
era vulgaris   Awesome, thanks guys. So, added to the list... -...   Jul 14 2016, 06:19 PM
era vulgaris   Also in my searches I read somewhere that the clut...   Jul 14 2016, 06:20 PM
wndsrfr   Also in my searches I read somewhere that the clu...   Jul 14 2016, 08:07 PM
76-914   Since this is your 1st time; 1, there is a bolt on...   Jul 14 2016, 06:30 PM
era vulgaris   Since this is your 1st time; 1, there is a bolt o...   Jul 14 2016, 06:58 PM
Mark Henry   You can do it by eyeball, a proper size dowel, or ...   Jul 14 2016, 06:36 PM
rhodyguy   Those are the parts I mentioned. I forgot the fork...   Jul 14 2016, 06:40 PM
saigon71   Decided to replace my RMS myself. First time I...   Jul 14 2016, 06:46 PM
era vulgaris   When you mention "crush washer" are yo...   Jul 14 2016, 06:56 PM
saigon71   When you mention "crush washer" are y...   Jul 14 2016, 07:56 PM
era vulgaris   Alright, all parts have been ordered. Thanks so m...   Jul 15 2016, 11:00 AM
jrblackbox   case of beer? just sayin.   Jul 15 2016, 12:47 PM
era vulgaris   case of beer? just sayin. That's always in ...   Jul 15 2016, 02:13 PM
catsltd   I just did mine,well still doing. Good Luck. If y...   Jul 15 2016, 01:44 PM
era vulgaris   I just did mine,well still doing. Good Luck. If ...   Jul 15 2016, 02:19 PM
catsltd   I just did mine,well still doing. Good Luck. If...   Jul 15 2016, 09:41 PM
- Lo-Fi Version Time is now: 4th July 2025 - 08:45 AM
