> 1.8 CHT sensor, Cant find any for sale
djway
post Jul 12 2016, 04:49 PM
I have a bad head temperature sensor on my 1974 1.8 914. I called Pelican Parts and they say they are not available. My car is just dumping fuel and I cant drive it until I get a new one.
Where can I find them?
Thanks
Dwayne
McMark
post Jul 15 2016, 08:24 AM
914 Freak!
The stock sensor is some spring based variable resistance setup. I don't really know how it works, and I'm sure for it's time it was the status quo in terms of technology, but nowadays we have thermistors. Solid state components.
I had two stock sensors go out on my turbo car, possibly due to heat, but regardless it's really not a component that should fail.
I found a unit that matches the stock heat-resistance curve and embed it into the shell of a stock unit. Which reminds me, I'd need core sensors to build off of.
Mueller
post Jul 15 2016, 09:09 AM
914 Freak!
QUOTE(McMark @ Jul 15 2016, 07:24 AM) *
Hey Mark,
Can this sensor be used with Megasquirt installs?
djway   1.8 CHT sensor   Jul 12 2016, 04:49 PM
Dave_Darling   The D-jet ones should work, at least to some exten...   Jul 12 2016, 04:55 PM
djway   The D-jet ones should work, at least to some exte...   Jul 12 2016, 05:04 PM
Big Len   Does this help? It's.....gulp, Auto Atlanta ...   Jul 12 2016, 05:26 PM
djway   Does this help? It's.....gulp, Auto Atlanta...   Jul 12 2016, 05:57 PM
The Cabinetmaker   http://www.bughaus.com/type_4_fuel_injectors_and_s...   Jul 12 2016, 05:51 PM
djway   http://www.bughaus.com/type_4_fuel_injectors_and_...   Jul 12 2016, 05:58 PM
jim_hoyland   Try a VW shop that's servicing buses....virtua...   Jul 12 2016, 06:40 PM
914Sixer   What is the part #? The bughaus page is showing ...   Jul 12 2016, 06:42 PM
djway   What is the part #? The bughaus page is showing...   Jul 12 2016, 09:22 PM
MarkV   http://www.ebay.com/itm/Porsche-Sensor-Cyl...kex...   Jul 12 2016, 11:46 PM
djway   http://www.ebay.com/itm/Porsche-Sensor-Cyl...kex...   Jul 13 2016, 03:23 AM
RohJay   [quote name='MarkV' post='2370833' date='Jul 12 2...   Jul 14 2016, 12:14 AM
saigon71   [quote name='MarkV' post='2370833' date='Jul 12 ...   Jul 14 2016, 07:02 AM
jcd914   Not to say that you don't need a CHT sensor bu...   Jul 13 2016, 12:45 AM
djway   Not to say that you don't need a CHT sensor b...   Jul 13 2016, 03:22 AM
djway   I have a bad head temperature sensor on my 1974 1...   Jul 13 2016, 12:46 AM
The Cabinetmaker   After hours of searching I finally found a place ...   Jul 15 2016, 04:51 PM
djway   Well, I ordered under that new part number and gue...   Jul 13 2016, 04:51 PM
914Sixer   I do not understand what happened to all the senso...   Jul 13 2016, 08:37 PM
Keith914   I have one recently removed from my '72, Yours...   Jul 13 2016, 08:56 PM
McMark   $30 I'll send you one of my custom ones t...   Jul 13 2016, 09:46 PM
djway   $30 I'll send you one of my custom ones ...   Jul 13 2016, 11:31 PM
Mikey914   $30 I'll send you one of my custom ones ...   Jul 14 2016, 12:24 AM
djway   $30 I'll send you one of my custom ones ...   Jul 17 2016, 01:11 AM
jim_hoyland   See:. http://www.ratwell.com/technical/TempSensorI...   Jul 14 2016, 06:31 PM
McMark   The stock sensor is some spring based variable res...   Jul 15 2016, 08:24 AM
Mueller   The stock sensor is some spring based variable re...   Jul 15 2016, 09:09 AM
McMark   Hey Mark, Can this sensor be used with Megasquir...   Jul 15 2016, 10:34 AM
djway   The stock sensor is some spring based variable re...   Jul 15 2016, 11:52 AM
Jeff Bowlsby   Which reminds me, I'd need core sensors to bu...   Jul 17 2016, 08:53 AM
McMark   Which reminds me, I'd need core sensors to bui...   Jul 17 2016, 09:27 AM
stugray   M10x1.00 bolts aren't easy to find, although...   Jul 17 2016, 11:25 AM
stugray   connect the sensor wire to the input of a switch w...   Jul 15 2016, 10:02 AM
Marty Yeoman   I like the way you think.   Jul 15 2016, 10:18 AM
djway   Since I have your attention :) After putting in ...   Jul 15 2016, 12:12 PM
catsltd   Since I have your attention :) After putting in...   Jul 15 2016, 01:55 PM
76-914   I'm of no help as I don't know LJet but I ...   Jul 15 2016, 02:26 PM
914_teener   I'm of no help as I don't know LJet but I...   Jul 15 2016, 03:18 PM
djway   I'm of no help as I don't know LJet but ...   Jul 15 2016, 03:54 PM
914_teener   [quote name='914_teener' post='2371901' date='Jul...   Jul 15 2016, 04:58 PM
djway   I'm of no help as I don't know LJet but I...   Jul 15 2016, 03:53 PM
McMark   Worked from 7am to 10:30pm yesterday. Just replie...   Jul 17 2016, 07:55 AM
catsltd   Worked from 7am to 10:30pm yesterday. Just repli...   Jul 17 2016, 08:16 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 02:56 PM
