era vulgaris |
J is for Genius ![]() ![]() ![]() Group: Members Posts: 983 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States ![]() |
Decided to replace my RMS myself. First time I've pulled a trans, so I want to make sure I have everything I need before I start.
- 12 point triple square bit for CV bolts - Flywheel lock - clutch alignment tool - Sabo RMS - Flywheel o ring - felt washer - crush washer - new CV gaskets - new schnorr washers for CV bolts Should I get a new pilot bearing? My engine and trans only have about 15,000 miles on them. Anything to do with the clutch fork that needs to be taken care of when the trans is removed? Is there anything else I'll need? Can all other bolts and washers be re-used? |
catsltd |
Member ![]() ![]() Group: Members Posts: 181 Joined: 7-June 15 From: Calgary Alberta Member No.: 18,814 Region Association: None ![]() |
I just did mine,well still doing.
Good Luck. If you think nothing will go wrong your wrong. My Pelican pilot guide thing worked well for me aligning my pressure plate etc. Wear safety galsses,unless you like lots of crap in your eyes. |
Lo-Fi Version | Time is now: 4th July 2025 - 07:20 AM |
