| djway |
Jul 12 2016, 04:49 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 787 Joined: 16-October 15 From: Riverside Member No.: 19,266 Region Association: Southern California |
I have a bad head temperature sensor on my 1974 1.8 914. I called Pelican Parts and they say they are not available. My car is just dumping fuel and I cant drive it until I get a new one.
Where can I find them? Thanks Dwayne |
| 76-914 |
Jul 15 2016, 02:26 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,876 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
I'm of no help as I don't know LJet but I wouldn't freak out about CHT senders. Buy one of Marks thermistors. There dead nuts on or but a variable resistor from Radio Shack for < $7 and dial in the value you need with an ohm meter or turn it until you get the idle you want. (IMG:style_emoticons/default/beerchug.gif)
| 914_teener |
Jul 15 2016, 03:18 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,270 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
I'm of no help as I don't know LJet but I wouldn't freak out about CHT senders. Buy one of Marks thermistors. There dead nuts on or but a variable resistor from Radio Shack for < $7 and dial in the value you need with an ohm meter or turn it until you get the idle you want. (IMG:style_emoticons/default/beerchug.gif) I am using one that McMark made for me to test a couple of years ago for my car which is inducted with the stock D-jet. It uses a modern thermistor that he made to test with a dedicated ground. It is running flawlessly. I think the dedicated ground helps. I think after a few years from the heat cycling the stock CHT ground uses the body of the CHT. Over time it builds up oxidation causing resistance. My theory FWIW. I'm not the EE that Stu is......I know enough of that shite to get myself into it and then ask for help. |
| djway |
Jul 15 2016, 03:54 PM
I'm of no help as I don't know LJet but I wouldn't freak out about CHT senders. Buy one of Marks thermistors. There dead nuts on or but a variable resistor from Radio Shack for < $7 and dial in the value you need with an ohm meter or turn it until you get the idle you want. (IMG:style_emoticons/default/beerchug.gif) I am using one that McMark made for me to test a couple of years ago for my car which is inducted with the stock D-jet. It uses a modern thermistor that he made to test with a dedicated ground. It is running flawlessly. I think the dedicated ground helps. I think after a few years from the heat cycling the stock CHT ground uses the body of the CHT. Over time it builds up oxidation causing resistance. My theory FWIW. I'm not the EE that Stu is......I know enough of that shite to get myself into it and then ask for help. Heck I don't need to know nuttin to dig in deep LOL (IMG:style_emoticons/default/lol-2.gif) |
| 914_teener |
Jul 15 2016, 04:58 PM
I'm of no help as I don't know LJet but I wouldn't freak out about CHT senders. Buy one of Marks thermistors. There dead nuts on or but a variable resistor from Radio Shack for < $7 and dial in the value you need with an ohm meter or turn it until you get the idle you want. (IMG:style_emoticons/default/beerchug.gif) I am using one that McMark made for me to test a couple of years ago for my car which is inducted with the stock D-jet. It uses a modern thermistor that he made to test with a dedicated ground. It is running flawlessly. I think the dedicated ground helps. I think after a few years from the heat cycling the stock CHT ground uses the body of the CHT. Over time it builds up oxidation causing resistance. My theory FWIW. I'm not the EE that Stu is......I know enough of that shite to get myself into it and then ask for help. Heck I don't need to know nuttin to dig in deep LOL (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/laugh.gif) ...."I've been thinking too much......HELP me"....... |
djway 1.8 CHT sensor Jul 12 2016, 04:49 PM
Dave_Darling The D-jet ones should work, at least to some exten... Jul 12 2016, 04:55 PM
djway
The D-jet ones should work, at least to some exte... Jul 12 2016, 05:04 PM
Big Len Does this help?
It's.....gulp, Auto Atlanta ... Jul 12 2016, 05:26 PM
djway
Does this help?
It's.....gulp, Auto Atlanta... Jul 12 2016, 05:57 PM
The Cabinetmaker http://www.bughaus.com/type_4_fuel_injectors_and_s... Jul 12 2016, 05:51 PM
djway
http://www.bughaus.com/type_4_fuel_injectors_and_... Jul 12 2016, 05:58 PM
jim_hoyland Try a VW shop that's servicing buses....virtua... Jul 12 2016, 06:40 PM
914Sixer What is the part #? The bughaus page is showing ... Jul 12 2016, 06:42 PM
djway
What is the part #? The bughaus page is showing... Jul 12 2016, 09:22 PM
MarkV http://www.ebay.com/itm/Porsche-Sensor-Cyl...kex... Jul 12 2016, 11:46 PM
djway
http://www.ebay.com/itm/Porsche-Sensor-Cyl...kex... Jul 13 2016, 03:23 AM
RohJay
[quote name='MarkV' post='2370833' date='Jul 12 2... Jul 14 2016, 12:14 AM
saigon71
[quote name='MarkV' post='2370833' date='Jul 12 ... Jul 14 2016, 07:02 AM
jcd914 Not to say that you don't need a CHT sensor bu... Jul 13 2016, 12:45 AM
djway
Not to say that you don't need a CHT sensor b... Jul 13 2016, 03:22 AM
djway
I have a bad head temperature sensor on my 1974 1... Jul 13 2016, 12:46 AM
The Cabinetmaker
After hours of searching I finally found a place ... Jul 15 2016, 04:51 PM
djway Well, I ordered under that new part number and gue... Jul 13 2016, 04:51 PM
914Sixer I do not understand what happened to all the senso... Jul 13 2016, 08:37 PM
Keith914 I have one recently removed from my '72, Yours... Jul 13 2016, 08:56 PM
McMark $30 I'll send you one of my custom ones t... Jul 13 2016, 09:46 PM
djway
$30 I'll send you one of my custom ones ... Jul 13 2016, 11:31 PM
Mikey914
$30 I'll send you one of my custom ones ... Jul 14 2016, 12:24 AM
djway
$30 I'll send you one of my custom ones ... Jul 17 2016, 01:11 AM
jim_hoyland See:. http://www.ratwell.com/technical/TempSensorI... Jul 14 2016, 06:31 PM
McMark The stock sensor is some spring based variable res... Jul 15 2016, 08:24 AM
Mueller
The stock sensor is some spring based variable re... Jul 15 2016, 09:09 AM
McMark Hey Mark,
Can this sensor be used with Megasquir... Jul 15 2016, 10:34 AM
djway
The stock sensor is some spring based variable re... Jul 15 2016, 11:52 AM
Jeff Bowlsby
Which reminds me, I'd need core sensors to bu... Jul 17 2016, 08:53 AM
McMark Which reminds me, I'd need core sensors to bui... Jul 17 2016, 09:27 AM
stugray
M10x1.00 bolts aren't easy to find, although... Jul 17 2016, 11:25 AM
stugray connect the sensor wire to the input of a switch w... Jul 15 2016, 10:02 AM
Marty Yeoman I like the way you think. Jul 15 2016, 10:18 AM
djway Since I have your attention :) After putting in ... Jul 15 2016, 12:12 PM
catsltd
Since I have your attention :) After putting in... Jul 15 2016, 01:55 PM
djway
I'm of no help as I don't know LJet but I... Jul 15 2016, 03:53 PM
McMark Worked from 7am to 10:30pm yesterday. Just replie... Jul 17 2016, 07:55 AM
catsltd
Worked from 7am to 10:30pm yesterday. Just repli... Jul 17 2016, 08:16 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:56 PM |
