| pwnsf |
Jul 17 2016, 12:29 PM
Newbie ![]() Group: Members Posts: 6 Joined: 28-September 15 From: San Francisco Member No.: 19,214 Region Association: None |
I've been having a issue with the 914 dying when I press the clutch to down shift or coming to a stop. The RPM's just drop to 0 and the car dies. It happens randomly and only when I'm coming to a stop or down shifting. When I'm shifting up it has never happened and the RPM's are great. The car runs perfectly otherwise. It will crank right back up when it dies at a stop or of coarse you can pop the clutch if its still moving and it will start right back up. If I take the car out of gear and just press the brake when stopping it doesn't happen either. It's very strange and I can't figure it out. Please any advice or help would be greatly appreciated.
| Perry Kiehl Clone |
Jul 17 2016, 12:35 PM
Unregistered |
Does it start and idle OK? The only time the engine dies is when the clutch pedal is pressed?
pwnsf Engine dies when clutch is pressed Jul 17 2016, 12:29 PM
pwnsf
Does it start and idle OK? The only time the eng... Jul 17 2016, 12:44 PM
Rand I'd be curious to know if you drop it into neu... Jul 17 2016, 12:35 PM
pwnsf
I'd be curious to know if you drop it into ne... Jul 17 2016, 12:47 PM
era vulgaris Do you have carbs or FI?
You should be coming to ... Jul 17 2016, 12:51 PM
pwnsf
You should be coming to... Jul 17 2016, 01:00 PM
rhodyguy is the clutch engagement point near the floor or u... Jul 17 2016, 12:56 PM
pwnsf
is the clutch engagement point near the floor or ... Jul 17 2016, 01:01 PM
stugray Check to make sure the clutch cable is not interfe... Jul 17 2016, 01:06 PM
pwnsf
Check to make sure the clutch cable is not interf... Jul 17 2016, 01:07 PM
rhodyguy clutch doesn't fully disengage and when you st... Jul 17 2016, 01:19 PM
zipedadoo Check your ground cables. I have seen cars that wo... Jul 17 2016, 01:28 PM
cuddyk :agree:
Sounds like an electrical problem. The c... Jul 17 2016, 06:18 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th September 2026 - 07:57 AM |
