> Engine dies when clutch is pressed
pwnsf
post Jul 17 2016, 12:29 PM
I've been having a issue with the 914 dying when I press the clutch to down shift or coming to a stop. The RPM's just drop to 0 and the car dies. It happens randomly and only when I'm coming to a stop or down shifting. When I'm shifting up it has never happened and the RPM's are great. The car runs perfectly otherwise. It will crank right back up when it dies at a stop or of coarse you can pop the clutch if its still moving and it will start right back up. If I take the car out of gear and just press the brake when stopping it doesn't happen either. It's very strange and I can't figure it out. Please any advice or help would be greatly appreciated.
stugray
post Jul 17 2016, 01:06 PM
Check to make sure the clutch cable is not interfering with the throttle cable in the center tunnel by the pedal cluster.
When this happens it usually results in the engine revving when the clutch is depressed, but stranger things have happened.
pwnsf
post Jul 17 2016, 01:07 PM
QUOTE(stugray @ Jul 17 2016, 12:06 PM) *
Thanks I'll check that out..
- Lo-Fi Version Time is now: 9th September 2026 - 07:58 AM
