OT: brake bleeding on newer ABS cars, what's your take? |
draganc |
Jul 25 2016, 10:59 AM
Senior Member Group: Members Posts: 725 Joined: 2-November 09 From: central new jersey Member No.: 11,000 Region Association: North East States |
Hi folks!
Just curious what the group's opinion is on changing/bleeding brake fluid on newer street driven cars (i.e. CLK500 @2000mls/year) with ABS: 1) Yes, every 2 years or 2) I have never done it and my car drives just fine Also, how much different is the work with ABS, compare to our 914s? Just trying to get some education before talking to my "new" car mechanic. Thanks, (IMG:style_emoticons/default/beerchug.gif) dc PS: I know this topic/questions will be opinionated. |
Chris914n6 |
Jul 25 2016, 12:45 PM
Jackstands are my life. Group: Members Posts: 3,337 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Brake fluid absorbs water so yes it needs changed. I wait until I do brakes.
Mark where the level is before if you are not putting in all new pads and rotors. It's a balanced system, if you "top it off" it will leak out and eat paint later when you push the cylinders back in to fit new meaty pads. ABS cars are a PITA. With a 914 or other non ABS car you can use a vacuum or pressure bleeder making it a 1 person job. ABS needs either a pedal pusher or dealer electronics. Side note- if it says you need dealer electronics you might just need a pedal pusher, as being a dealer tech is a solo job. |
Lo-Fi Version | Time is now: 9th June 2024 - 03:32 AM |
