> High idle problem with 2lt engine
Creamsicle New Zealand
post Jul 24 2016, 10:43 PM
Region Association: Australia and New Zealand
Hi all, I'm wondering if any one could help me with a problem I have. When either cold or hot my engine runs at 1600RPM. I have looked for any air leaks, all the hoses are new. The only things I can find are the following - After removing the throttle body I noticed the surface the gaskets sits on is uneven due to powder coating so I sanded this area back to bare metal and it is a lot flatter, this had no effect on the RPM. When the engine is cold I can block of the air hose going to the cold running injector and the revs come down to about 1200RPM, as the engine gets warm the cold running injector stops operating as it should. The air intake valve on the side of the throttle body is wound fully in but the valve does not appear to seat properly, when I hold it up to the light I can see gaps both side of the valve, is this normal?
The other thing I noticed when holding the throttle body up to the light was the butterfly valve in the throttle body has gaps around most of the sides of it when closed, is this normal or is this an indication of wear?
In the butterfly valve is a hole approx. 3mm. When I block this off the revs come back to 1100RPM which is getting closer to what it should be.
Any one have any thoughts on this please?
Thanks Steve
era vulgaris
post Jul 25 2016, 02:24 PM
J is for Genius
Throttle Position Switch
Creamsicle New Zealand   High idle problem with 2lt engine   Jul 24 2016, 10:43 PM
Jeff Bowlsby   Appears you have a vacuum leak somewhere, its typi...   Jul 24 2016, 11:13 PM
Creamsicle New Zealand   Appears you have a vacuum leak somewhere, its typ...   Jul 24 2016, 11:48 PM
OU812   Had same problem with the 2.0 liter Turned out th...   Jul 25 2016, 07:29 AM
Creamsicle New Zealand   Had same problem with the 2.0 liter Turned out t...   Jul 25 2016, 02:18 PM
The Cabinetmaker   Had same problem with the 2.0 liter Turned out ...   Jul 25 2016, 02:41 PM
era vulgaris   Throttle Position Switch   Jul 25 2016, 02:24 PM
Chris H.   Throttle Position Switch/Sensor. It's also ...   Jul 25 2016, 02:26 PM
Jeff Bowlsby   I think he was referring to the throttle body itse...   Jul 25 2016, 02:49 PM
The Cabinetmaker   I think he was referring to the throttle body its...   Jul 25 2016, 03:24 PM
OU812   I think he was referring to the throttle body its...   Jul 25 2016, 06:37 PM
914_teener   I don.t know if you are running the stock distribu...   Jul 25 2016, 03:04 PM
Jeff Bowlsby   I don.t know if you are running the stock distrib...   Jul 25 2016, 03:33 PM
Creamsicle New Zealand   Thanks for the input, TPS seems OK from what I can...   Jul 25 2016, 04:14 PM
Spoke   I looked through your thread but couldn't tell...   Jul 25 2016, 04:36 PM
Rand   2L is Djet. I wouldn't suspect the MPS because...   Jul 25 2016, 04:49 PM
Amphicar770   You can also take an unlit propane torch and probe...   Jul 25 2016, 04:54 PM
jcd914   The TPS can be mis-adjusted and prevent the thrott...   Jul 25 2016, 05:03 PM
914_teener   The TPS can be mis-adjusted and prevent the throt...   Jul 25 2016, 06:33 PM
914_teener   ...there is a small ball bearing under the plate I...   Jul 25 2016, 06:36 PM
Creamsicle New Zealand   Thanks every one it will take me a couple of days ...   Jul 25 2016, 07:36 PM
porschetub   Thanks every one it will take me a couple of days...   Jul 26 2016, 01:12 AM
The Cabinetmaker   Like others have said, tps and mps won't make ...   Jul 25 2016, 07:41 PM
Spoke   ...mps won't make it idle higher... I'm...   Jul 26 2016, 05:50 AM
Dave_Darling   Over-advanced timing will also make the idle faste...   Jul 25 2016, 11:45 PM
The Cabinetmaker   When the mps diaphragm fails it goes full rich. Wi...   Jul 26 2016, 06:47 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 02:09 PM
