| matchpoint |
Jun 28 2016, 04:58 PM
Newbie ![]() Group: Members Posts: 16 Joined: 19-March 16 From: Oregon Member No.: 19,783 Region Association: Pacific Northwest |
I have my 76 - 914 engine and fuel tank out of my car during my frame off restoration. I want to replace the 2 plastic/nylon fuel lines in the tunnel with an OE product and not use the stainless or mild steal fuel line. I want to go back original and after 40 years of service I want to replace the plastic lines. Looks like everyone says go stainless but I want to go with the OE plastic.
Does anyone have a part number of a replacement plastic/nylon tubing of the same size as the OE plastic tubing. I think it is 7MM OD size. Auto Atlanta told me to just blow out the OE plastic lines and don't waste your time replacing. Looks like an easy replacement while the car is apart and all I need to know is a P/N of a plastic/nylon fuel tubing I can get @ NAPA. Thanks |
| 914_teener |
Jul 26 2016, 11:40 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,270 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
The failure was the battery placement which caused the early failures. The 914 was a transition model and the decision to move the fuel pump was an easier decision logistically form an engineering prospective than moving the battery in my opinion. I never moved my pump for that reason and my lines are in good shape and not on the pressure side of the pump. Now the connections and rubber hoses in the injection loop in the engine compartment. I check those all the time. I sleep at night and drive my car alot....in really hot weather. |
matchpoint Plastic Tunnel Fuel Lines Jun 28 2016, 04:58 PM
napasteve I'm having a hard time understanding why you w... Jun 28 2016, 05:19 PM
Jeff Bowlsby OE fuel lines are NLA. The 1970-74 lines are nylo... Jun 28 2016, 05:28 PM
OU812 Try the search function
There is mucho info on i... Jun 28 2016, 05:52 PM
914Sixer Bel-Metric has the new version of the fuel line yo... Jun 28 2016, 06:02 PM
mepstein Makes sense not to use the best product available ... Jun 28 2016, 06:10 PM
pete000 This is the one part I would not want "Factor... Jun 28 2016, 06:20 PM
green914 Pelican Parts has the how to instructions for repl... Jun 29 2016, 10:56 AM
JawjaPorsche If I was making an investment like you are, why ta... Jun 29 2016, 01:49 PM
Jeff Bowlsby "Polyamide" is the larger family name fo... Jun 29 2016, 01:54 PM
matchpoint
"Polyamide" is the larger family name f... Jun 29 2016, 02:19 PM
barefoot http://www.parker.com/literature/Parflex/B.../CAT%... Jun 29 2016, 02:47 PM
Jeff Bowlsby It will take some workmanship care and research to... Jun 29 2016, 03:01 PM
Catorse They used asbestos for decades and lead for centur... Jun 29 2016, 03:44 PM
Jeff Bowlsby
The plastic lines are a safety issue, plain and s... Jun 29 2016, 04:04 PM
mepstein I would think the chance of it getting nicked by t... Jun 29 2016, 05:01 PM
Mueller Nylon tubing for fuel is approved for aircraft use... Jun 29 2016, 05:08 PM
napasteve Jeff,
I just replaced my OE metal/plastic lines t... Jun 29 2016, 05:11 PM
Catorse Whoaa......are we saying the 914 has AIRCRAFT QUAL... Jun 29 2016, 08:23 PM
Whoaa......are we saying the 914 has AIRCRAFT QUA... Jun 29 2016, 08:53 PM
John Jentz
Whoaa......are we saying the 914 has AIRCRAFT QUA... Jun 30 2016, 09:35 AM
matchpoint
Whoaa......are we saying the 914 has AIRCRAFT QU... Jun 30 2016, 10:14 AM
porschetub
Whoaa......are we saying the 914 has AIRCRAFT QU... Jul 26 2016, 11:26 PM
Amphicar770 If you want to have original hoses because you thi... Jun 29 2016, 08:26 PM
matchpoint Three reasons Porsche may have used plastic fuel l... Jun 29 2016, 09:09 PM
Jeff Bowlsby We should not advocate for either the nylon or SS ... Jun 29 2016, 10:30 PM
mbseto
Which is more durable against battery acid - I d... Jun 30 2016, 08:46 AM
oakdalecurtis Sorry to those who might have read this story in p... Jul 26 2016, 12:22 PM
veekry9
Old lines have ruined a few 914s,so,a rigorous ... Jul 27 2016, 03:16 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:21 AM |
