making a KEP clutch work, any tricks? |
worn |
Jul 26 2016, 11:42 AM
can't remember Group: Members Posts: 3,164 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Well, I was almost ready to lower the car off jack stands and since I installed the axles I figured it was time to start the car just to make the wheels turn. With the motor off the gears all shift. I have spent a lot of time aligning shifter forks and getting the linkage right. But with the engine spinning I get a very disagreeable noise when I try to shift with the clutch pedal down.
It is a KEP 3.2 to 901 conversion in which I received a starter ring, pressure plate clutch disc and throwout bearing. I bought it used from someone on the board (cannot currently find who) so I really do not know what I have for certain. At install it all went together well, but the clutch disk, pressure plate and bearing all seemed to be stock-sourced parts. Are there any tricks I should be thinking about. I would prefer to leave the tranny where I put it, but obviously that may not be possible. So even if it has to come off I am seeking advice. Also if anyone has info on what I should have in the package that could help. Not saying someone sent me the wrong thing: saying I can make a mess of a parts bin that I have. helppp... |
Rotary'14 |
Jul 26 2016, 11:55 AM
Senior Member Group: Members Posts: 753 Joined: 24-April 05 From: Los Angeles Member No.: 3,977 |
Did you adjust the clutch cable? It might still be dragging with the pedal down all the way. If so,, you might have to put a shim under the pivot ball in the transmission, this helps the t/o bearing push a bit further.
-Robert |
worn |
Jul 27 2016, 09:15 AM
Did you adjust the clutch cable? It might still be dragging with the pedal down all the way. If so,, you might have to put a shim under the pivot ball in the transmission, this helps the t/o bearing push a bit further. -Robert Oddly, the instructions say to remove the washer. I think I did not actually remove the washer, perhaps working by force of habit at that point. |
Lo-Fi Version | Time is now: 10th June 2024 - 07:47 PM |
