Newbie Question 2: Weber Carburetors |
amfab |
Jul 28 2016, 02:24 PM
Member Group: Members Posts: 393 Joined: 17-May 16 From: Los Angeles Member No.: 20,004 Region Association: None |
I just bought a 74 2.0. Previous owner says previous owner rebuilt it out to 2.1 a few years ago but there is no documentation. Regardless, it IS a GA with 3 bolt intakes so I will assume at least 42mm intake valves.
It came with dual Weber 36idfs with 32 venturis. The motor seems a bit anemic at the higher RPM. To me—quite an amateur at this kind of stuff—it kind of makes sense because the throttle bodies seem a bit small for the motor (it seems that a lot of the type 1 guys use 36idfs on sub-2 litre motors). I just had the car tuned up and it runs very nicely, but not a lot of power and it flattens out fast above 4kRPM I considered megasquirt, but because I have linkage and manifolds I was thinking going the easier and cheaper route of 40 or 44 idfs. After doing a bit of research, my thoughts are either 40idfs with 34 venturis or 44idfs with 36 venturis. Just a little more oomph will be able to carry me until I eventually do a six conversion in a couple years. Are 44idfs too much carb for the 2.0 (or possible 2.1)? Unfortunately, there is no documentation on the cam either. I (and my mechanic) are thinking its stock or close to it. Any advice would be greatly appreciated. Thank you -Andrew |
colingreene |
Jul 28 2016, 11:38 PM
Senior Member Group: Members Posts: 729 Joined: 17-October 13 From: Southern California Member No.: 16,526 Region Association: Southern California |
sounds like the cam is more your problem than anything else.
porschetub |
Jul 29 2016, 02:02 AM
Advanced Member Group: Members Posts: 4,706 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
sounds like the cam is more your problem than anything else. 36 IDFs should be ok ,you could be suffering a lean condition @ high rpm,take it for a good hard run and check your plug colour,it should be a rich brown . Remember that it isn't the throat size of the carbs it is the venturi size that dictates the power,you could go to say 34 vents and end up with better performance over the power range than say 40 or 44's can provide as you will lose some of the lower end power that you drive in most of the time. Is your ignition really and truly up to the mark ,for instance is the distributor advancing totally at higher rpm,all these factors come in to play,tell us more and that will really help cause you should still be making power @ higher rpm regardless of the cam . Many members can help you on here,cheers EDIT....don't wait too long for six conversion otherwise you will be struggling to find a motor for a decent price. |
Lo-Fi Version | Time is now: 8th June 2024 - 06:38 PM |
