Newbie question 1: Dashboard |
amfab |
Jul 28 2016, 02:23 PM
Member Group: Members Posts: 393 Joined: 17-May 16 From: Los Angeles Member No.: 20,004 Region Association: None |
Hi I am new to this forum. Thanks in advance for the help.
Car is a 1974 2.0. I am replacing the radio and have a roll of basket weave vinyl to do the rest of the dash as well. My Question is: was the radio plate always separate in terms of vinyl basket weave or did the vinyl ever come as one contiguous piece from the drivers side all the way to the seam at the glove box with no seam for the radio plate, or were the radio plates always separate? -Andrew |
914Next |
Jul 29 2016, 02:40 AM
Senior Member Group: Members Posts: 699 Joined: 28-July 14 From: Ephraim Wisconsin Member No.: 17,695 Region Association: Upper MidWest |
My understanding is that all radios were dealer installed such that none were really "factory". As a result, I think you would likely see many variations. One example is mine where they actually used plain black vinyl on the radio plate even though there is basket weave on the rest of the dash. I know this is as delivered since the car is very completely documented and i have had conversations with the original owner about this. I suspect for some reason they did not have basket weave in stock when they installed the radio...or they grabbed a radio from another Porsche as a quick solution and did not bother to change the vinyl.
Mikey914 |
Jul 29 2016, 03:12 AM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
My understanding is that all radios were dealer installed such that none were really "factory". As a result, I think you would likely see many variations. One example is mine where they actually used plain black vinyl on the radio plate even though there is basket weave on the rest of the dash. I know this is as delivered since the car is very completely documented and i have had conversations with the original owner about this. I suspect for some reason they did not have basket weave in stock when they installed the radio...or they grabbed a radio from another Porsche as a quick solution and did not bother to change the vinyl. Correct I have the delete, DIN, and OEM style plates if you need any. |
914Next |
Jul 29 2016, 03:24 AM
My understanding is that all radios were dealer installed such that none were really "factory". As a result, I think you would likely see many variations. One example is mine where they actually used plain black vinyl on the radio plate even though there is basket weave on the rest of the dash. I know this is as delivered since the car is very completely documented and i have had conversations with the original owner about this. I suspect for some reason they did not have basket weave in stock when they installed the radio...or they grabbed a radio from another Porsche as a quick solution and did not bother to change the vinyl. Correct I have the delete, DIN, and OEM style plates if you need any. Thanks. I did buy an original plate with basket weave but the car is so original that I've decided to leave it as delivered. Some of these quirky things are what makes a particular car interesting. Steve |
Lo-Fi Version | Time is now: 9th June 2024 - 10:28 AM |
