Found a relay board!, Member sending me one, thanks! |
oakdalecurtis |
Jul 28 2016, 06:40 PM
Oakdalecurtis Group: Members Posts: 1,328 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
I think I found my charging problem. Here's a picture of the bottom of my relay board. I'm told that the big hole and melting on the edges is not normal, and the VR contact spades don't stay up. (What in the world might cause that?) Does anyone have another relay board on the shelf they aren't using?
Thanks |
GeorgeRud |
Jul 30 2016, 09:56 AM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
Try removing the voltage regulator off the board and plugging it directly into the rear engine harness. That should let you know if it is the board. The pins for the VR really just allow the regulator to mount on the board.
oakdalecurtis |
Jul 30 2016, 11:43 AM
Try removing the voltage regulator off the board and plugging it directly into the rear engine harness. That should let you know if it is the board. The pins for the VR really just allow the regulator to mount on the board. Thanks George, but I'm not sure I'd plug it in the right spot and another member is sending me an almost new board with all the components on it including another VR. I'll try that and see what happens next. Appreciate your advice though. |
Lo-Fi Version | Time is now: 31st May 2024 - 05:15 PM |
