malcolm2 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,749 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States ![]() ![]() |
I noticed the last time i parked that the red "G" light had come on slightly. Got in yesterday and it was on bright and the volt meter was at 10.5. Revving the engine did not help either.
I checked the belt tension and decided to tighten it. Took a 20 minute drive to Nashville and all was well. At the last stop i saw the dim G light again. Then bright for a while. Then out. What is the prognosis? I have about 20k miles on the alt wire harness and gel battery. Maybe 10k on the rebuilt alt. |
malcolm2 |
I did "search" but rarely found a fix. Lots of trouble shooting but never a break through I started her today and after a 10 minute warm up the light went out. Thanks for the replies I'll keep everyone posted.
Rand |
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,413 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None ![]() |
malcolm2 |
I started her today and after a 10 minute warm up the light went out. Wait... Before 10 minutes went by, did you try wiggling the VR?? It takes one second to see if that makes the light go out. (IMG:style_emoticons/default/confused24.gif) Letting it warm up for 10 minutes only wastes 10 minutes. I didn't wiggle it, I pulled it and the ALT wire and touched up the spades with emory cloth. Knocked some white surface corrosion off, but it did not solve my light issue. |
Lo-Fi Version | Time is now: 3rd September 2025 - 09:45 PM |
