malcolm2 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,749 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States ![]() ![]() |
I noticed the last time i parked that the red "G" light had come on slightly. Got in yesterday and it was on bright and the volt meter was at 10.5. Revving the engine did not help either.
I checked the belt tension and decided to tighten it. Took a 20 minute drive to Nashville and all was well. At the last stop i saw the dim G light again. Then bright for a while. Then out. What is the prognosis? I have about 20k miles on the alt wire harness and gel battery. Maybe 10k on the rebuilt alt. |
jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,870 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
malcolm2 |
WOW, that is great. I had forgotten that Ratwell had so much good info. (IMG:style_emoticons/default/piratenanner.gif) I'll get to the VR tests this afternoon. Clark |
malcolm2 |
WOW, that is great. I had forgotten that Ratwell had so much good info. (IMG:style_emoticons/default/piratenanner.gif) I'll get to the VR tests this afternoon. Clark Has anyone done the RATWELL test? I got some crazy numbers. Plus I seem to have an intermittent problem. Once the engine is warm the ALT light goes out at idle. But if I shut it down then restart the warm engine, I get the light on at idle.... RATWELL says to check the voltage at the ALT harness I took the plastic cover off of the board behind the driver and was able to get my VOM probe into the back of the ALT harness plug as follows.... the black probe was alligator clipped to the battery neg. Red wire (D+) with the ALT light on and engine idling. I need 14v and I get 1.8v Grn wire (DF) with ALT light on and engine idling. I need 5.0v and I get 1.8 Red wire again, with the ALT light on and engine reving, I need 14v and I get 1.7v Grn wire with ALT light on and engine reving, I need 5v and it goes to MAX. If I slowly rev the engine, it creeps past 18volts to 35 volts then the meter goes to --1-----. Something ain't right, but what is it? BTW i took emory cloth to the spades for the VR and the ALT harness and cleaned them up. |
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,238 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
I took the plastic cover off of the board behind the driver and was able to get my VOM probe into the back of the ALT harness plug as follows.... the black probe was alligator clipped to the battery neg. Red wire (D+) with the ALT light on and engine idling. I need 14v and I get 1.8v Grn wire (DF) with ALT light on and engine idling. I need 5.0v and I get 1.8 Red wire again, with the ALT light on and engine reving, I need 14v and I get 1.7v Grn wire with ALT light on and engine reving, I need 5v and it goes to MAX. If I slowly rev the engine, it creeps past 18volts to 35 volts then the meter goes to --1-----. Something ain't right, but what is it? BTW i took emory cloth to the spades for the VR and the ALT harness and cleaned them up. D+ voltage is generated by the alternator and should equal the battery voltage. DF voltage drives the magnet in the rotor which in turn generates voltage to D+ and charges the car battery. If the VR is bad, it will not drive DF properly and the alternator may produce too much or too little voltage. If the alternator is bad, it may not drive V+ (which drives the VR) and the alternator will not charge the battery. You can test the alternator by removing the VR and shorting D+ to DF. This is equivalent to the VR providing maximum drive current to the rotor magnet. With the car running, the alternator should generate more than 16V. If the alternator doesn't provide >16V and the GEN light stays on, likely the alternator needs replaced. |
malcolm2 |
You can test the alternator by removing the VR and shorting D+ to DF. This is equivalent to the VR providing maximum drive current to the rotor magnet. With the car running, the alternator should generate more than 16V. If the alternator doesn't provide >16V and the GEN light stays on, likely the alternator needs replaced. To be clear, I remove the VR. Use a short wire to connect the D+ to the DF female connections on the relay board now visible from removing the VR. Which should be the 2 that are side by side (or the btm of the triangle formed by the 3 connectors) VOM on + & - of the battery. start the car. read the meter. So if the ALT gives me >16 volts I can assume I need a VR? |
Spoke |
You can test the alternator by removing the VR and shorting D+ to DF. This is equivalent to the VR providing maximum drive current to the rotor magnet. With the car running, the alternator should generate more than 16V. If the alternator doesn't provide >16V and the GEN light stays on, likely the alternator needs replaced. To be clear, I remove the VR. Use a short wire to connect the D+ to the DF female connections on the relay board now visible from removing the VR. Which should be the 2 that are side by side (or the btm of the triangle formed by the 3 connectors) VOM on + & - of the battery. start the car. read the meter. So if the ALT gives me >16 volts I can assume I need a VR? Correct, the 2 side by side spades. Correct on the procedure. What you are doing in effect is fooling the alternator to appear like the VR is trying to maintain maximum charging/voltage output. If you do get 16+ volts the alternator is able to charge the battery. Even 14+ volts would be good considering if your battery is deeply discharged from not having a functioning electrical charging system. |
Lo-Fi Version | Time is now: 3rd September 2025 - 09:46 PM |
