High Idle, but only when driving or warm., Cold, and sitting... 1000 RPM. Driving...1400 ?? |
MikeInMunich |
Aug 4 2016, 02:44 AM
Member Group: Members Posts: 392 Joined: 19-November 13 From: Munich, Germany Member No.: 16,674 Region Association: None |
Greetings from Munich gentlemen!
As seen in the title, my car (1973 1.7 converted to 2 liter, D-Jettronic F.I.) idles at 1000 after starting and letting it sit. When I take it out in the road it quickly changes to 1400. It still idles at 1400 when stopped after the car is warm. 1) I think my AAR (auxiliary air regulator) valve isn't working at all. Disconnecting the vacuum hose, the idle shot up to about 3000 and covering it with my finger 100% it went back down to where it was before I had detached it from the AAR. So the AAR should have been OPEN as the car wasn't warm yet, but it seems to be closed 100%. Strangely, the idle only goes up after the car is out on the road / is warm...but not even yet near normal operating temperature. I'm thinking the AFR is leaning out under load and after the car is fully warmed up. (IMG:style_emoticons/default/idea.gif) I currently don't have AFR or CO values. I will have the CO measured cold and after warming up in a few days. Here's another issue and question fer y'all. While looking into the bay yesterday I noticed a substantial leak at one of the fuel injectors. I didn't mess with it much (checking the seating of the seal) but after I drove the car and it was warm, I looked again and it had stopped leaking. I thought it could have something to do with temp and fuel pressure (IMG:style_emoticons/default/confused24.gif) Starting up the car cold this morning however, I checked again, and there was still no leak. Does anyone have any idea what could cause an apparently intermittent leak like this? Perhaps just fudging with it gently got a seal to sit better, but I'm skeptical about that. Thanks for your feedback! (IMG:style_emoticons/default/beerchug.gif) By the way, I do know about this thread on Rennlist, which is a tremendous resource: http://members.rennlist.com/pbanders/djetparts.htm Mike in Munich |
era vulgaris |
Aug 4 2016, 01:39 PM
J is for Genius Group: Members Posts: 982 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States |
If your AAR is stuck open, or if it is entirely removed from the system, you should have a very low idle on a cold start. So low that you shouldn't really be able to hold an idle at all. You'd basically have to keep your foot on the gas for a couple minutes until the engine was warm enough for you to even hold an idle. If you're starting out at 1k rpm when cold, with no AAR installed, then either your idle screw is set too high, or you have a vacuum leak somewhere.
With the AAR working properly, and no vacuum leaks, and the entire system working properly, you should be starting out at ~1800rpm on a cold start which should then come down to ~900 rpm within the first few minutes of driving as the engine warms and the AAR closes. It doesn't take the car getting up to full operating temp for the AAR to close. It only takes a couple minutes. If your idle goes up as the engine warms up, then it could be a stuck AAR, however you've definitely got other issues if your cold idle speed is 1k rpm. Where is your idle screw set? Try setting your idle to 900 once the car is warm. Like I said, with the AAR removed your cold idle speed should be so low that you need to hold the gas pedal with your foot to keep the car running. Also, I'd recommend never driving a car that you even remotely suspect has a fuel leak. |
Lo-Fi Version | Time is now: 2nd June 2024 - 06:28 AM |
