| JamesB2 |
Aug 6 2016, 02:06 PM
Newbie ![]() Group: Members Posts: 5 Joined: 13-March 14 From: San Diego, CA Member No.: 17,113 Region Association: None |
hey folks,
Let me start with the situation: A while back I noticed some fraying in my clutch cable and instead of taking care of it then I thought, "it'll hold." It did hold but then that day came where the clutch pedal dropped to the floor and luckily I was driving in a 25 mph zone and stuck in second gear. Now, I have searched and searched and came up with a general idea of how to replace the cable. At this point in time, I have the cable disconnected from the clutch pedal, took the pin out. I have read where people say tying a string to the cable allows you to snake the new cable through and avoid wrapping around the accelerator. Now in one post I read to unscrew the end of the clutch cable at attaches to the clutch. Is it necessary to remove that end piece? I feel like using the hole would make tying a string to it more secure and easier. Thanks in advance, James |
| JamesB2 |
Aug 6 2016, 03:18 PM
Thanks gents!
Got it attached to the pedal and just have to attach to the transmission now. Thanks again!! |
JamesB2 Clutch cable replacement Aug 6 2016, 02:06 PM
injunmort disconnect the cable at both ends. remove clevis ... Aug 6 2016, 02:20 PM
steuspeed I didn't use a string to snake mine in. Just s... Aug 6 2016, 02:31 PM
JamesB2 Any idea what the size of the bolts used to adjust... Aug 6 2016, 06:08 PM
BeatNavy The bolts at the end of the cable (tranny side) us... Aug 6 2016, 06:31 PM
JamesB2
The bolts at the end of the cable (tranny side) u... Aug 6 2016, 06:43 PM
porschetub Cut the cable down before fitting by 10-12mm @ the... Aug 6 2016, 08:10 PM
injunmort no offense, but don't cut anything. dial the c... Aug 6 2016, 08:18 PM
porschetub
no offense, but don't cut anything. dial the ... Aug 7 2016, 05:52 PM
maf914 When your cable broke, did you recover all of the ... Aug 7 2016, 04:53 PM
injunmort i too am running the cofle cable, but i did have t... Aug 7 2016, 06:28 PM
Larmo63 That's funny, when my cable snapped (I too saw... Aug 8 2016, 12:04 AM![]() ![]() |
Lo-Fi Version | Time is now: 15th April 2026 - 06:56 PM |
