> Clutch cable replacement, couple questions.
JamesB2
post Aug 6 2016, 02:06 PM
hey folks,
Let me start with the situation:
A while back I noticed some fraying in my clutch cable and instead of taking care of it then I thought, "it'll hold." It did hold but then that day came where the clutch pedal dropped to the floor and luckily I was driving in a 25 mph zone and stuck in second gear.
Now, I have searched and searched and came up with a general idea of how to replace the cable. At this point in time, I have the cable disconnected from the clutch pedal, took the pin out. I have read where people say tying a string to the cable allows you to snake the new cable through and avoid wrapping around the accelerator.
Now in one post I read to unscrew the end of the clutch cable at attaches to the clutch. Is it necessary to remove that end piece? I feel like using the hole would make tying a string to it more secure and easier.
Thanks in advance,
James
injunmort
post Aug 6 2016, 08:18 PM
no offense, but don't cut anything. dial the clevis end down and tighten the gland nut, if it is too long and the transmission, a couple washers to take up the slack is perfectly acceptable. cutting either end of the cable is a bad idea even if you have the correct die to repair the threads.
- Lo-Fi Version Time is now: 15th April 2026 - 06:56 PM
